Raspberry Pi
hum,
since i updated to 2.2.5 emoncms (local, i only use local) stops random with updating, i see the time when it stops updating on the settings menu. (time stands still and the others move on)
the mqtt and all others work fine...
wierd...
i looked at it... its no patern in the hold up of emoncm thread, mqtt and the program works fine..only emoncms not...
  • 1 year later...
9 hours ago, Salman Kazi said:
Hi Manie . I want to check how it works. Am unable to open icc website.  From where can I download?
you can try again
10 minutes ago, Salman Kazi said:
Ok its working now  . Can I get free trial for icc as an new with my raspberry as well with icc.
Send me a email  with your machine ID. Machine ID is located in ICC under the settings page.
  • 8 months later...
Hi all. I’ve been reading about the raspberry pi and wanted to install one to my inverter to be able to remove the laptop I have running 24/7 with the watchpower program running.
what is the recommended model of the pi I should get and how would I go about setup.
do I just install windows on it, is this possible or is there some other form of os ?
appreciate your assistance
3 minutes ago, Sidewinder said:
@Doron,
From the ICC www.:
ICC Pi compatible Raspberry Pi devices:
  • Raspberry Pi 2
  • Raspberry Pi 3/3B
  • Raspberry Pi 3B+
  • Raspberry Pi 4
Personally, I wouldn't go for less that a 3B+, specially if you have other cpu sapping app's you are going to run.
thanks. i will get a Pi 3B+ then. how would i go about installing a OS/ or what i the recommended OS to be installed onto the Pi. i want to be able to monitor the inverter to see voltage, what the PV is generating etc. and all this through a remote log in like any desk or some other form.
Don't worry about O/S's..Just go with the default, then O/s is transparent...
Quick overview:
You download the image from iccsoftware.co.za.
Burn image on SD card.
Boot Pi with SD card. Connect keyboard & screen.
Configure Pi for your LAN/Wifi environment (to "see" the Internet)
Connect Type B USB cable to inverter & Pi.
Run ICC(should run Automatically)
Get Machine ID
E-mail ICC to get temp/permanent license key.
The "Help" page on ICCSoftware.co.za has got this all. Just read there.
Configure VNC for remote access as well.
Later you can try running Windows10 on another pi (4 with 4GB RAM recommended), if you that way inclined, but ICCSoftware are only developing upgraded/fixes on the linux version.
