Sign in to follow this
PaulF007
Weather Station
I got a weather station over the weekend and have managed to get it online. Posting to www.wunderground.com now , it works quite well but I want to import some of the info into emon. Has anyone played with weather stations before?
Share this post
Link to post
I'm building my own using a Raspberry Pi and various sensors. Surely you can hookup those sensors to a Rasperry Pi and do the same? You would need to figure out which components they used and then write / use some code off the net to post the data ;)
Share this post
Link to post
Tell us more about it
Share this post
Link to post
The receiver is quite capable from what I could work out but I use some third party software , Cumulus , to read the station. It currently does make provision for sending the data to weather underground but I can't figure how to get it to Emon. I suspect that Cumulus might have the option there in the custom settings but for now it eludes me.
Share this post
Link to post
What programming language was it written in? There are many samples on the net of sending data to emoncms from different platforms and if Cumulus is open source (it looks like), then it should be too difficult to get the data to emoncms.
Share this post
Link to post
Hi Paul
I use Cumulus for my station.  The new CumulusMX may have EMON support and also has a Linux version if I remember correctly.  http://sandaysoft.com/forum/viewtopic.php?f=27&t=12908#p101008
Share this post
Link to post
Cool for now I am also sending it to WU and for instant view it is quite nice , but I do like to fiddle with the data , hence emon , there is a PHP script that you can run to import the data from WU to emon but it sort off feels counter productive to upload the data to WU and then download it to emon again ... :)
Share this post
Link to post
@PaulF007, I use CumulusMX running on a RaspberryPi to read the station data and send it to WU. I also use Meteotemplate (www.meteotemplate.com) to record to a local database and display on a website. You can try contacting the developer (Jachym), he is very responsive and eager to develop new features.
C
Share this post
Link to post
This guy is really good with the work that he has done, I will need to setup a Linux server to run his stuff. If I have a local server then I could look at sending the info from that server to emon..
Share this post
Link to post
Cool for now I am also sending it to WU and for instant view it is quite nice , but I do like to fiddle with the data , hence emon , there is a PHP script that you can run to import the data from WU to emon but it sort off feels counter productive to upload the data to WU and then download it to emon again ... default_smile.png
https://openenergymonitor.org/emon/node/2869
Have a look at the above link...
Sent from my SM-G800F using Tapatalk
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
