djacobs Posted September 12, 2017 Share Posted September 12, 2017 Hello All, My batteries has finally packed up. (Extremely Hot) and Boiling. How do I bypass the Axpert to not charge and only run off Utility for the moment. Thanks All Daniel Quote Link to comment Share on other sites More sharing options...
Chris Hobson Posted September 12, 2017 Share Posted September 12, 2017 The closest you are going to come to not charging is set Program 1 to Utility. Program 2 to 10 A. Program 11 to 2A. Program 16 Cut (utility). It might be prudent to disconnect your batteries and bypass the inverter. Mark and pilotfish 2 Quote Link to comment Share on other sites More sharing options...
___ Posted September 12, 2017 Share Posted September 12, 2017 25 minutes ago, Chris Hobson said: It might be prudent to disconnect your batteries and bypass the inverter. ^^^ This. Do this. Mark 1 Quote Link to comment Share on other sites More sharing options...
Guest Posted September 13, 2017 Share Posted September 13, 2017 Do NOT use them batteries. Somewhere on the forum I posted a picture of a UPS blown to pieces, because the batts exploded. Quote Link to comment Share on other sites More sharing options...
___ Posted September 13, 2017 Share Posted September 13, 2017 1 minute ago, The Terrible Triplett said: Do NOT use them batteries. Somewhere on the forum I posted a picture of a UPS blown to pieces, because the batts exploded. Yup, someone else (I forgot who) also posted a picture of a melted battery, one of those Silver Calcium jobbies that had thermal runaway. Side note: If you don't have a bypass switch installed... now you know why that was a bad idea :-) Mark and Chris Hobson 2 Quote Link to comment Share on other sites More sharing options...
maxomill Posted September 15, 2017 Share Posted September 15, 2017 if times are tough and you want to keep the system going then rather get some small bats even 7ah gate motor bats just to trick the system into working . you will have very little backup but you can still run on solar if you change your settings . I've heard bats blow-up and its not pleasant cheers Quote Link to comment Share on other sites More sharing options...
___ Posted September 15, 2017 Share Posted September 15, 2017 1 minute ago, maxomill said: get some small bats even 7ah gate motor bats With the SCC's tendency to overshoot? I wouldn't do that even with more expensive kit. Even my blue controllers sometimes overshoots when there is cloud-edge going on. Though I've never seen more than 29.2V, that's 0.4V over, on a battery that's 20 times larger. No ways would I do this... except if the object was to blow sh*t up! :-) maxomill 1 Quote Link to comment Share on other sites More sharing options...
Guest Posted September 16, 2017 Share Posted September 16, 2017 On 9/15/2017 at 11:09 AM, plonkster said: ... except if the object was to blow sh*t up! :-) Now you go me interested ... what are we blowing up next? Who is going to try the 7ah batts? Put them in a acid resistant holder and lets see what happens!!! Seriously, @maxomill, a suggestion is to go battery shops / battery recycling places and beg / plead with them for 2nd hand batts that still works. People have UPS'es and sometimes 1 batt fails, leaving the rest of the bank still working. You probably will pay the lead price per kg for them, about R8-R9 per kg. Note: When you do this, always feel the batt temps during charging to see if one does not overheat. I burnt the living dinges out of my thumb when I touched a pole on a battery that was shorting whilst the inverter was powering a 300w load. Quote Link to comment Share on other sites More sharing options...
dax021 Posted September 16, 2017 Share Posted September 16, 2017 5 hours ago, The Terrible Triplett said: Seriously, @maxomill, a suggestion is to go battery shops / battery recycling places and beg / plead with them for 2nd hand batts that still works. Dream on. Been trying this approach for about 2 yrs. These guys know the value of batteries, and will rather "recon" the half good batteries then resell them as 80% good for R 800 to R 1000 each. I sent my 4 x T1275"s to a place to try and recover them, but the guy says they are totally poked, no chance. Fortunately, he didn't charge me, even though he quoted R 50 per batt if it doesn't work, due to his electricity usage. I think he's offering me R 7/kg, must still go round and negotiate for replacements. ibiza 1 Quote Link to comment Share on other sites More sharing options...
maxomill Posted September 17, 2017 Share Posted September 17, 2017 hi guys before you go all out at me . lets find out what size system djacobs has cheers Quote Link to comment Share on other sites More sharing options...
___ Posted September 17, 2017 Share Posted September 17, 2017 10 hours ago, maxomill said: before you go all out Oh I agree, wasn't targeted at you personally, juts more of a general observation. In principle I agree with you, one can band-aid things with a collection of smaller batteries, but I suspect the Axpert's can't be set to charge lower than 2 amps, which already sort of tells you to look i the 20ah range. Gotta hash out all the details as you say. maxomill 1 Quote Link to comment Share on other sites More sharing options...
