Sign in to follow this
Chris Hobson
PV Array Sizing Tool
I have been designing systems and discovered that clients can change the goalposts sometimes more than once a day. I was using the Midnight solar sizing tool and ended up tired of re-entering panel specs. So I designed my own.
The yellow fields are for the user to alter. There is a drop down list of inverters and if your inverter is not on the list you can go to the inverter sheet and add your own specs. The same with panels there is a open column to add your specific panels. Canadian solar 260W and probably 265W are set to disappear from our shores so I will remove them from the list and add others.
Having set you inverter  then you can set minimum and maximum temperature. Remember these are panel temperatures and although panel minimum and ambient minimum will be the same panel maximum is likely to be 20-30°C higher than ambient temp. Minimum temperatures are important as panels voltages INCREASE with lower temperatures. I know several folk who exceed their SCC's Vmaxbut if you want to do it by the book this spreadsheet will help you. When your panels Vmp is below the MPPT minimum you are warned with pink text as this may or may not be a problem.
You can then play around with number of panels per string and number of strings to find a combination that works for your inverter.
PV String Tool.xlsx
Share this post
Link to post
11 hours ago, Kalito said:
Geez man this is very very useful. I have been looking for such a simple and yet comprehensive tool. Great work
I have it on good authority that is is not particularly user-friendly. I'll try fix it in version 2.
Share this post
Link to post
Maybe because before one figures out where to go to enter custom values they are subjected to other module figures I guess for information. But for now it does the job. I eargerly await the update - lol
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
