Paul Coetzee Posted January 15, 2018 Share Posted January 15, 2018 Hi, I hope you will be able to assist me in the questions below. Below is a screen dump of the messages I am referring to. I would really appreciate your reply on this issue. 1) Is there a list of all the messages the WatchPower Software can issue? 2) What does each of these messages mean? 3) What action does each of these messages require from me? 4) Which messages (E.g "communication lost" and "communication restored") I don't have to worry about ? Quote Link to comment Share on other sites More sharing options...
Chris Hobson Posted January 15, 2018 Share Posted January 15, 2018 The communication lost and restore is a log of communication between the Axpert and WatchPower being lost and restored. Overload alarm is just that Axpert drawing more than 4kW. Quote Link to comment Share on other sites More sharing options...
Paul Coetzee Posted January 16, 2018 Author Share Posted January 16, 2018 Thanks Chris. Quote Link to comment Share on other sites More sharing options...
SnoopySniper Posted April 29, 2019 Share Posted April 29, 2019 Good Day Can someone please assist with the correct settings for the mail function. I tried different settings with the help of google but to no avail. Thank you Greetings Quote Link to comment Share on other sites More sharing options...
rastert111 Posted April 29, 2019 Share Posted April 29, 2019 (edited) port should be 587 or try 465 if it fails.Also you will need to enable "Allow less secure apps" in security settings of account. if it still fails, try typing complete username i.e. [email protected] This will not work if you have 2 Factor Authentication setup on your account, in that case better create account for inverter only rather than using existing account edit: link for allowing less secure apps, you should be signed in. https://myaccount.google.com/lesssecureapps Edited April 29, 2019 by rastert111 Quote Link to comment Share on other sites More sharing options...
SnoopySniper Posted April 29, 2019 Share Posted April 29, 2019 Thank you for the info. I've tried all the suggestions but still keep on getting the "test failed" result. Will keep on exploring. Greetings Quote Link to comment Share on other sites More sharing options...
Greglsh Posted April 29, 2019 Share Posted April 29, 2019 Hi SnoopySniper As far as I know, the SMTP (sending) server on gmail requires ssl/tls encryption, is there any option for that, I think ssl is port 465 and if using tls then port 587. Who is your internet ISP? Maybe you could use their smtp server rather. So maybe look at these https://www.domains.co.za/knowledgebase/435/South-African-ISP-SMTP-Settings.html As long as your use your isp's smtp server it should work. Quote Link to comment Share on other sites More sharing options...
