Guest Posted January 29, 2018 Share Posted January 29, 2018 22 hours ago, mohammedbera2 said: In south Africa what's the best angle is 30° OK Being in nylstroom / modimolle ? Please advise Here is is again, way back I posted all this on the forum. http://solarelectricityhandbook.com/solar-angle-calculator.html Quote Link to comment Share on other sites More sharing options...
mohammedbera2 Posted February 4, 2018 Author Share Posted February 4, 2018 According to calculator I got 42° - 66°- 90° from vertical according to me that's 48° - 24° - 0° from horizontal 48+24+0÷3 =24° also have a NW facing roof @15° Will it make a big difference NW compared to N facing Or will it just produce power latter Quote Link to comment Share on other sites More sharing options...
SilverNodashi Posted February 5, 2018 Share Posted February 5, 2018 7 hours ago, mohammedbera2 said: According to calculator I got 42° - 66°- 90° from vertical according to me that's 48° - 24° - 0° from horizontal 48+24+0÷3 =24° also have a NW facing roof @15° Will it make a big difference NW compared to N facing Or will it just produce power latter If you cannot mount it at 24 degrees, it would / might produce a little less solar energy. Ideally, your panels need to be perpendicular to the sun, i.e. "face" the sun at a 90 degree angle. But that isn't always possible, or (financially / physically) viable. On small systems, it doesn't always make financial sense to build / buy a solar tracker, for your panels to track throughout the day. And thus it is often cheaper to add upto 20% more PV, you can. For example, instead of using 12x 250W panel for 3000W, use 12x 300W panels instead to get 3600W. This will then help for the shortfall incase your panels are not aligned 90 degrees to the sun. If you look at larger commercial installations, most shopping centers have their panels mounted flat on the roof, and not at an angle facing the sun. The main reason for this is to cater for strong wind resistance on those open roofs. So instead of mounting at an angle, more panels are used. mohammedbera2 1 Quote Link to comment Share on other sites More sharing options...
pilotfish Posted February 5, 2018 Share Posted February 5, 2018 10 hours ago, mohammedbera2 said: also have a NW facing roof @15° The roof pitch at 15' will make the system very effective in spring/summer/autumn, but less effective in winter - if anything I would prefer to see it the other way round (favoring winter), but it will probably make a difference of 5-10% over the year. The NW pointing roof is similar situation - great in the early morning late afternoon, not so great in late afternoon early morning- probably 5% loss overall. I dont think it makes financial sense to change any angles, if you are worried about losing 15% throughout the year then rather add 15% more panel area than try and change angles. ___ and mohammedbera2 2 Quote Link to comment Share on other sites More sharing options...
___ Posted February 5, 2018 Share Posted February 5, 2018 2 hours ago, pilotfish said: NW pointing roof NW is much better than NE. If you can't get North, and you have to choose between NW and NE, go with NW. mohammedbera2 1 Quote Link to comment Share on other sites More sharing options...
Guest Posted February 5, 2018 Share Posted February 5, 2018 5 hours ago, plonkster said: ..., go with NW. In CPT that makes sense, seeing sun sets very late in summer. But elsewhere, would it really have that much benefit, in like Nylstroom? Which side do the summer rains come from, the ones that come late afternoon, IF that is still happening? I would be more focused on winter in Tvl, as then one uses the most power. For in Cpt, winter is a wee bit of a waste to focus on as it is rainy season, at least supposed to be, or overcast a lot. Quote Link to comment Share on other sites More sharing options...
mohammedbera2 Posted February 5, 2018 Author Share Posted February 5, 2018 6 hours ago, plonkster said: NW is much better than NE. If you can't get North, and you have to choose between NW and NE, go with NW. Was just thinking not sure if anyone tried this: I have 9 x320w panels Going to be 3 strings of 3 what if I put 3 to face NE @ 15 ° and ( front roof ) 3 north and last @ 30° ( on a frame ) 3 to face NW@ 15° ( side roof) Quote Link to comment Share on other sites More sharing options...
SilverNodashi Posted February 5, 2018 Share Posted February 5, 2018 9 hours ago, pilotfish said: The roof pitch at 15' will make the system very effective in spring/summer/autumn, but less effective in winter - if anything I would prefer to see it the other way round (favoring winter), but it will probably make a difference of 5-10% over the year. The NW pointing roof is similar situation - great in the early morning late afternoon, not so great in late afternoon early morning- probably 5% loss overall. I dont think it makes financial sense to change any angles, if you are worried about losing 15% throughout the year then rather add 15% more panel area than try and change angles. Agreed. If he has enough roof space for more / bigger panels, go for it. You can easily scale upto about 60% more than the MPPT's range, permitted you stay within the VOC limits. Quote Link to comment Share on other sites More sharing options...
SilverNodashi Posted February 5, 2018 Share Posted February 5, 2018 1 hour ago, The Terrible Triplett said: In CPT that makes sense, seeing sun sets very late in summer. But elsewhere, would it really have that much benefit, in like Nylstroom? Which side do the summer rains come from, the ones that come late afternoon, IF that is still happening? I would be more focused on winter in Tvl, as then one uses the most power. For in Cpt, winter is a wee bit of a waste to focus on as it is rainy season, at least supposed to be, or overcast a lot. Yes. The afternoon rays are much more intense than the early more sun rays ___ 1 Quote Link to comment Share on other sites More sharing options...
SilverNodashi Posted February 5, 2018 Share Posted February 5, 2018 52 minutes ago, mohammedbera2 said: Was just thinking not sure if anyone tried this: I have 9 x320w panels Going to be 3 strings of 3 what if I put 3 to face NE @ 15 ° and ( front roof ) 3 north and last @ 30° ( on a frame ) 3 to face NW@ 15° ( side roof) Can you take some pics of your roof? If you can point North, mount them North. Quote Link to comment Share on other sites More sharing options...
Chris Hobson Posted February 5, 2018 Share Posted February 5, 2018 2 hours ago, mohammedbera2 said: Was just thinking not sure if anyone tried this: I have 9 x320w panels Going to be 3 strings of 3 what if I put 3 to face NE @ 15 ° and ( front roof ) 3 north and last @ 30° ( on a frame ) 3 to face NW@ 15° ( side roof) If I remember correctly you have 2 Axperts therefore 2 MPPTs and should have panels facing in 2 directions rather than 3. All the panels on one MPPT should face the same direction and have the same tilt. I do know some of the solar pump installers face panels in two different directions on a single MPPT. Pump MPPTs are much more forgiving. mohammedbera2 and pilotfish 2 Quote Link to comment Share on other sites More sharing options...
Guest Posted February 5, 2018 Share Posted February 5, 2018 1 hour ago, SilverNodashi said: Yes. The afternoon rays are much more intense than the early more sun rays Are you sure? The angle of the sun through the atmosphere is the same, it feels hotter in afternoons yes, for it baked the earth the whole day. Quote Link to comment Share on other sites More sharing options...
mohammedbera2 Posted February 5, 2018 Author Share Posted February 5, 2018 2 hours ago, SilverNodashi said: Can you take some pics of your roof? Quick drawing hope you will verstaan Quote Link to comment Share on other sites More sharing options...
Guest Posted February 5, 2018 Share Posted February 5, 2018 1 hour ago, mohammedbera2 said: Quick drawing ... Ons verstaan ... interesting problem to solve. My first thought: Any chance of a ground mounted array, keeping shade in consideration? Quote Link to comment Share on other sites More sharing options...
mohammedbera2 Posted February 5, 2018 Author Share Posted February 5, 2018 3 minutes ago, The Terrible Triplett said: My first thought: Any chance of a ground mounted array, No chance at all - 2m from boundary and walls and roof 4m high Quote Link to comment Share on other sites More sharing options...
Guest Posted February 5, 2018 Share Posted February 5, 2018 1 minute ago, mohammedbera2 said: No chance at all - 2m from boundary and walls and roof 4m high O shiite. Nothing like pitched roof facing North North West in Cape Town. Quote Link to comment Share on other sites More sharing options...
Guest Posted February 5, 2018 Share Posted February 5, 2018 Build a lapa, afdak, for a braai or whatever, and put the panels on as roof sheets, facing and pitched to perfection? Quote Link to comment Share on other sites More sharing options...
Mark Posted February 6, 2018 Share Posted February 6, 2018 7 hours ago, mohammedbera2 said: Quick drawing hope you will verstaan String 1: NE facing roof top of "n" String 2: NW facing roof "n's" right leg You will then have the best of both worlds - morning, midday and evening power generation! My 2c Mark pilotfish, mohammedbera2 and Chris Hobson 3 Quote Link to comment Share on other sites More sharing options...
SilverNodashi Posted February 6, 2018 Share Posted February 6, 2018 7 hours ago, mohammedbera2 said: Quick drawing hope you will verstaan In my opinion, it would work fine if you have all the panels on your North-West facing roof, i.e. the one on the left - permitted there's enough space. Early in the morning, say 7am, take a photo of that roof and see where the sun hits it. Then late in the afternoon, say 17:30, take another photo and see where the sun hits it. In winter it might be a different scenario though. Quote Link to comment Share on other sites More sharing options...
mohammedbera2 Posted February 6, 2018 Author Share Posted February 6, 2018 2 minutes ago, SilverNodashi said: Early in the morning, Left side of left roof is in shade till about 8/9h The top NE has sun (guessing )till around 15h00 Quote Link to comment Share on other sites More sharing options...
SilverNodashi Posted February 6, 2018 Share Posted February 6, 2018 Just now, mohammedbera2 said: Left side of left roof is in shade till about 8/9h The top NE has sun (guessing )till around 15h00 eish. Ok. The biggest problem you'll have with the West + East string, is that your roof doesn't face East or West either, so at some stage one, or both of those strings will probably get more shade than it should as well. And in Winter it would probably be a problem, depending on how low the sun goes in Nylstroom that time of the year. In which case you would need to add more panels to make up for the loss. mohammedbera2 1 Quote Link to comment Share on other sites More sharing options...
viper_za Posted February 6, 2018 Share Posted February 6, 2018 13 hours ago, The Terrible Triplett said: In CPT that makes sense, seeing sun sets very late in summer. But elsewhere, would it really have that much benefit, in like Nylstroom? Most people leave home early so having lots of morning power not as good as being able to use a little more solar when you get back after work Quote Link to comment Share on other sites More sharing options...
pilotfish Posted February 6, 2018 Share Posted February 6, 2018 (edited) Seperate into 2 arrays as follows, depending on shading (assuming 2x MPPT as mentioned by @Chris Hobson) - the system will work great. Most PV systems work hard in the morning to charge batteries etc, and then start to idle one batteries reach float, so that being the common case it makes sense to favour NE array if you had to pick one because you are likely to have excess capacity in the afternoon anyway. Edited February 6, 2018 by pilotfish additional info Mark, mohammedbera2 and Chris Hobson 3 Quote Link to comment Share on other sites More sharing options...
