Mark
Array Temperature Monitoring (Work In Progress)
I have a small temperature experiment starting today...
I managed to source some iButtons (temperature only) to measure the temperature at 2 different points on my PV array.
Buttons are now installed and I'll give them a few weeks to collect data.
Some initial specs:
  • Zinc corrugated roof/Aluminium adjustable frame (tilt = 45deg)
  • 15 min reading intervals
  • Button 1:  Bottom - Located inside of the panel frame but NOT on the glass backing (about 150mm from roof)
  • Button 2:  Centre - Located inside of the panel frame but NOT on the glass backing (about 400mm from roof)
  • Button 3:  Top - Located inside of the panel frame but NOT on the glass backing (about 700mm from roof)
  • The array is 6 x 310w panels long so the buttons are placed in  middle of the array. (Panel size = 1800mmx900mm)
I should be able to plot the 3x sets of PV readings on a spreadsheet with hopefully weather data as well (maybe only temperature ;) )
Share this post
Link to post
I have a similar setup running for some time already, but used some DB1820 sensors connected to a Raspberry Pi. On average, the temperature below my panels are 10 degrees cooler than in direct sun light.
Share this post
Link to post
Nice!
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
