Frixter Posted February 6, 2018 Share Posted February 6, 2018 Hi All. I am new to the Forum , but I need some assistance with my latest installation. I have some knowledge, but wouldn't consider myself an expert. My latest Install: 3 x 5kVA Synergi (MUST Solar) inverters 48V connected in Parallel 18 x Canadian Solar 330W Panels 4 x 2,4 kWA Li Ion Batteries (Pylon Tech) The problem I'm having is, that apparently there is no way of monitoring these units without installing Wifi RTU's. I purchased 3 x RTU's (as per the Manufacturers instruction) , but I do not get any data feedback from the units on the Cloud Based monitoring. All the instructions I received only Indicate connection via RJ 45, but the Battery Pack uses one of the ports to communicate with the Inverters. I connected the devices via a RS232 to USB type "A" cable using a USB Type "A" to Type "B" adapter (Purchased from Communica). All the units display "Online" on the Cloud system. Thanx in advance Quote Link to comment Share on other sites More sharing options...
SilverNodashi Posted February 6, 2018 Share Posted February 6, 2018 4 hours ago, Frixter said: Hi All. I am new to the Forum , but I need some assistance with my latest installation. I have some knowledge, but wouldn't consider myself an expert. My latest Install: 3 x 5kVA Synergi (MUST Solar) inverters 48V connected in Parallel 18 x Canadian Solar 330W Panels 4 x 2,4 kWA Li Ion Batteries (Pylon Tech) The problem I'm having is, that apparently there is no way of monitoring these units without installing Wifi RTU's. I purchased 3 x RTU's (as per the Manufacturers instruction) , but I do not get any data feedback from the units on the Cloud Based monitoring. All the instructions I received only Indicate connection via RJ 45, but the Battery Pack uses one of the ports to communicate with the Inverters. I connected the devices via a RS232 to USB type "A" cable using a USB Type "A" to Type "B" adapter (Purchased from Communica). All the units display "Online" on the Cloud system. Thanx in advance would you mind sharing a link to the make & model of your inverter? Quote Link to comment Share on other sites More sharing options...
