Coulomb
Patched firmware based on version 73.00
The beta versions of patched firmware 73.00a are here: LFP,  and other chemistries.
It's split into two posts only because of a problem with multiple attachments and the recently updated forum software.
Ironically, the forum software needs to be patched to host the patched firmware <_<
Share this post
Link to post
@Coulomb my 2 Axperts (Proline branded) have now been running flawlessly for a week with your and @weber's version 73.00a firmware. They seem to run cooler too, I guess because the fans are running continuously although quite slowly. I also installed an 8 inch mains fan in a box at the top between the inverters which blows air into the tops of both inverters.
Is it likely that further modifications to the code may be made before the final version is released or will the Beta just be declared final.
Share this post
Link to post
Great to hear that.
Quote
The fans also run faster by a factor of 5/3 when charging, solar or AC. I think that the idea is to keep the electronics cooler during the day (most charging is via solar, presumably), so it's still fairly quiet at night, but gets extra cooling when the sun shines.
Quote
Yes, there will be no further modifications. We were going to make the present version final a few weeks ago, but various things cropped up. There will eventually be a version that acts exactly the same, but displays the firmware version page as LC1 or LF1 instead of BC1 or BF1.
Share this post
Link to post
Thank you for the information @Coulomb. Must say I find the new display options most useful. Sure hope you and @weber will continue your mods for as long as you find ways to improve the Axperts' performance. Thanks again for it all thus far.
Share this post
Link to post
@Coulomb, I'm not a member of the other forum but I read through that quickly. Some ideas.
First, 30 seconds seems a bit short. Just thinking about the Victron BMV's full detection (tail current drops to below a certain configurable percentage for a configurable time) defaults to at least several minutes, and the general advice is 10 to 15 minutes.
I think the reason for the 2A figure might be for practical reasons. I read somewhere (might have been your forum) that the Voltronic doesn't have a current sensor on the battery side, instead it infers the current from the AC measurements (The Multi does that too). This means battery measurements under about 1A is inaccurate (the same is true on the Multi), so quite likely the lowest whole number it can actually measure is 2 ampere. You guys know the guts of that thing better than I do, so it is possible that I am way off base here... but the number rang a bell for me. On planet blue it is very similar, the lowest sort of accurate number you can set is 2 amp per parallel unit.
Share this post
Link to post
Hi,
I have a 5 kva inverter like axpert with 80 A MPPT controller ( no name brand) it had 72.90 version and today it stops running and show error 90. I tried to flash but the reflash tool stops with connect fail see attached .pictures.  I test the communication with monitoring tool and it works. I changed the cables etc Please let me know if you have any ideea why I cannot conect to inverter.
P.S: the inverter is made for Europe.
Thank you
Share this post
Link to post
Hi There,
TO be clear about patching the firmware, do we need to install  the base first of 73? before installing 73.00b?
Or is 73.00b all inclusive?
(Now to hunt down the cable :( ) I am still on 52...
Share this post
Link to post
73.00b is self-contained. You do not need to load 73.00 first.
However I note that the change we made in going from 73.00a to 73.00b is only intended to allow our patched firmware to run on older models of genuine Voltronic inverters, not clones. Coulomb and I feel it is perfectly legitimate for Voltronic to protect their R&D investment by disabling their firmware on clones, so please don't ask us to defeat this protection. And it's quite possible we couldn't, even if we wanted to.
We feel sorry for people who bought clones without being aware of it. It's not your fault. But unfortunately, we can't help you without effectively helping the clone maker, and we consider that to be unethical. So you need to take this Error 90 problem up with your supplier.
Share this post
Link to post
12 hours ago, bravla said:
Please let me know if you have any idea why I cannot connect to inverter.
Error 90 is undocumented, so we're all speculating here. Your reflash problem could be independent of error 90, caused by one of the several niggling reasons why the reflash tool won't connect. For example, maybe COM1 isn't your USB to RS232 adapter, but some other (virtual) serial device. Maybe the USB to serial adapter doesn't work in this application; some seem to work with more PC variants than others.
But assuming that you have not made one of those errors, one theory is that Voltronic Power have done something to trap clone manufacturers that improperly copy their firmware. The version number 72.90 is new to me; it could be that this is a clone manufacturer's minimally changed copy of the official firmware 73.00.
If this is true, the clone manufacturers are doing something illegal and unethical. To fix it, they'll have to write their own firmware from scratch, including the flash boot loader that is presumably bricking their clients' machines. (Again, this is if the cloner trap theory is valid). As an additional penalty, they'll have to either provide some special tool to flash program the new firmware, or every customer will have to send their CPU daughter board or perhaps the whole machine back to the factory (or have a new one sent out). Unfortunately, this greatly inconveniences the customers as well, who have done nothing wrong, merely wanting a good deal (and who doesn't?). I guess that Voltronic hope that this will push more customers in the future away from the no-name clones to the branded products. Of course, it might also backfire, turning customers away from a manufacturer who would cause them so much pain. I guess we'll see which way it goes, once more assuming that the cloner trap theory is correct.
Another possibility is that error 90 has some other meaning that I don't know of, but it seems relevant that the machine stopped with error 90 before you had flash updating problems.
Share this post
Link to post
thank you for yours answer I will try to change the CPU board with other with old firmware to see if error wil disapear.
Share this post
Link to post
...genuine Voltronic inverters, not clones....
How does one find out of it is a clone orr true Voltronic? Model Numbers?
Share this post
Link to post
I'm sorry Allen, but I don't know a general rule. The number of brands and model numbers that genuine Voltronics are sold under is huge. You can see a partial list at the start of this page. The only clone brand I'm aware of so far is "Must". But there are undoubtedly other brands and model numbers in both categories.
Share this post
Link to post
Posted (edited)
The beta version of patched firmware 73.00c is available now:
http://forums.aeva.asn.au/viewtopic.php?p=67551#p67551
It has minor tweaks to improve battery current accuracy (though minor, they took a lot of effort and time, mainly by Weber), and fixes two more bugs that were present in the original factory firmware, regarding settings changes from the LC display and buttons.
Link wasn't live; it's a beta version
Share this post
Link to post
On 2018/04/01 at 6:36 PM, ibiza said:
If you have ICC connected to the inverter you must remove that cable.
that was the reason for my firmware update showing the exact image of the reflash tool in  bravla's post
disconnecting sorted the update issue, i do not think i had the error messages, my lcd light just went dead - THAT WAS A SCARY MOMENT! B)
Share this post
Link to post
So you have performed an update successfully now?
Re the scary moment: you have to remember that during reflashing, the main software is completely disabled; you are talking only to the boot loader. With a successful download, all that usually happens is that the LCD and LEDs merely freeze at whatever they were displaying last; you might not even notice that anything is different if you weren't looking for it. But when a reflash has comms errors or doesn't start properly, it can be in a sort of limbo between normal operation and normal firmware updating, so that neither the Reflash tool nor the LCD seems to respond. That's when you need to keep a clear head and figure out how to rescue the operation.
The other thing to keep in mind is that there is only one serial port that talks to the outside world. So if you have ICC talking away on the USB port while you are trying to update via the RS232 port, the two sets of serial data are going to get badly intermingled; they might even wire-OR and mingle at the bit level, I've never sorted that out.
Share this post
Link to post
They almost all work this way. I worked for a company who made software for fitness watches. The watch has a bootloader and when you update firmware over a USB cable, the main code is not running, just the bootloader. I wrote code for a chinese card payment terminal once. That had a bootloader as well, we even implemented enough HTTP in it to do remote downloads. Turns out the device also has its own bootloader, holding the right keys kicks it into a kind of passthru so that you can communicate directly to the Motorolla GSM modem in it to update THAT firmware! This recipe is so old you almost cannot imagine anyone doing it differently.
Even the Arduino has a bootloader (in fact, that's the entire magic of it!). For a second or so right after power on it checks the condition on its input pins, and if right, it accepts a new program on the serial port and writes it to flash. That means you don't need an expensive hardware programmer, the chip is its own programmer. You can literally make your own arduinos by flashing the free bootloader to new ATMega 328 chips (which is the point of it being open source).
The usual trick is that the main firmware has a checksum and if it doesn't match the bootloader doesn't load it. Instead it just remains in bootloader mode. That means you can restart the firmware upload without bricking it. Alternatively, the other way is to always check if someone wants to upload firmware for half a second right after power on (I believe the dreambox works that way). As long as you don't trash the bootloader, you can almost always recover.
Share this post
Link to post
for me, the electro-technically challenged guy, the best sentence in your comment :)
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
