Majoor Doppies
ARTSOLAR PV Panels
Hello All.  Does anyone have a considered opinion or experience in respect of ArtSolar panels made in Pinetown. They seem OK to me but I would like to have some thoughts before I buy. Thanks.
Share this post
Link to post
Hi all
I am in Centurion and have been a member of the forum since August 2017.
Thanks to the abundance of information here, I have learned a lot and got all of my questions answered merely by browsing around.
Regarding ArtSolar panels, I bought 9 of these (72 cell 315WP) end of October 2017.  They seem to perform the same as the initial 3 x Enersol panels that I had installed before upgrading my system.  The specifications are identical between the 2 makes and visually the build quality appears to be the same.
Considering that they are only in operation for 6 months, only time will tell their reliability.
I have also installed a second parallel Axpert when the 9 panels were added.
Interesting observation is that the MPPT responds much faster when the load increases than with the 3 x Enersol panels connected to one Axpert.
Would this be due to installing the second Axpert, split of PV between the inverters (2 strings of 3 panels per inverter) or could it be due to the panels.
Insight from one of the experts here will be appreciated.
Share this post
Link to post
Posted (edited)
I don't believe it could be anything inherent in the panels. I think it's mainly the total power of 12 panels versus 3.
Edit: I originally speculated about ramping the current by fixed PWM values. I've since reviewed the code and decided that this is not correct.
Share this post
Link to post
I think so too. Assuming the 9 panel side is a 3x3 arrangement, the voltage will be pretty similar, but... reading up on how the incremental conductance algorithm works (which they may or may not use), the power peak is where dI/dV == -I/V. The magnitude of dI/dV can be used as an indication of how far away you are from the power point. Larger current means you should get there faster.
Of course similar shenanigans are possible with perturb and observe. Larger numbers, better signal :-)
Share this post
Link to post
I recently bought three 265W ArtSolar panels to be used together with a Victron Multiplus and MPPT solar charger and a few other goodies in a caravan installation.
The panels worked exactly as expected.
When they sell you the panels the give you the test data for each individual panel. I also had a tour around the production facility. It's not micky mouse third world stuff.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
