Gabriël Posted May 19, 2018 Share Posted May 19, 2018 please see pdf soc jump charge pattern.pdf Quote Link to comment Share on other sites More sharing options...
___ Posted May 19, 2018 Share Posted May 19, 2018 I would ideally want to see the charge current and voltage as well. What you want to see is 1) voltage held at absorption level, 2) current dropping off nicely to under 2A, 3) SoC rising while all this is happening, and then after the current has been that low for long enough... should follow the jump in the BMV SoC. Gabriël 1 Quote Link to comment Share on other sites More sharing options...
Gabriël Posted May 19, 2018 Author Share Posted May 19, 2018 (edited) it seems to fit the pattern, although i'll monitor and let you know. in the meantime images of the situation just before 100 soc Edited May 19, 2018 by gabriel replace images with better one Quote Link to comment Share on other sites More sharing options...
