Jan Breet
single phase via 3 phase
I have an project coming up for farmers nearby Mafeking.
The all have 3 phase motors on their bore holes.
My question is, is it cheaper to change the motor to single phase, or must I get a 3 phase inverter solar system?
Share this post
Link to post
There are various reasons why getting a solar pump would be better.
Power factor, current requirements.
Three phase may well be more efficient which is important for solar. But it will cost a lot more inverter wise.
But a bad power factor will be really, really wasteful in which case an actual solar pump would be far better choice.
Power factor in 3 phase motors can easily be a problem, hence mentioning it.
Share this post
Link to post
I'm sitting in the same boat. Need to solarize 3 pumps on the farm. One of them is an "ancient" pump that uses about 4.5A on 400V. It's a belt driven pump and the electrical motor is probably 10 years old. The one quote I got for a 2.2Kw solar system was R72,000!
Share this post
Link to post
What backup can I use for a submersible pump. If the sun is not shinning for more than 7 days?
Probably rain quite a bit during 7 days without sun.
Any above ground tanks to pump into during sunny times ?.
Share this post
Link to post
Batteries, but as Chris said it would be more economical to have a genset if the sun doesn't shine for 7 days!.
Share this post
Link to post
Rural Eskom users pay through the nose - sometimes R2500 -R3000 in line fees, levies etc. BEFORE you have used a SINGLE unit of power. If you are going solar under these circumstances you do not want to maintain your Eskom connection for the "what-if" scenarios. You plow that R2500 into your installation and make other alternatives for rainy days.
Share this post
Link to post
I have the same problem and looking into Three-Phase VSD Solar Pump Controller MicroCare has one. You do need a VSD compatable drive.
The other option I found was at www.fullcirclesolar.co.za  -- They have one that runs on all moters.
Down side is that they all need around 500V ( Lots of panels )
Still worth it as the Eskom pump point alone coasts me R1800 a month.
Share this post
Link to post
On 5/2/2017 at 0:00 PM, jacobez said:
An option would be to replace the 3P DOL starters with a 1P input - 3P ouput VSD.
We ended up installed 3x 5KVA Axpert inverters + solar panels, which then could be used for other purposes as well. Other brands could also be used but this was the cheapest option.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
