pvoutput.org
Gerald_db
What are you Guys using to output to PVOutput.org?
I've been trying to purchase Solarmon but it seems the Paypal link does not work and sending emails gets no responses from the solarmon guys.
AICC do not work for me  i cannot select ports when running the application.
My system
Axpert  24 Volt 3KVA  plus (1500w pv)
1530w PV (2 strings  3series 255w panels)
200AH 24v battery bank
My system
Do yours only have usb?
Just now, Manie said:
What is the max pv input on yours. Mine is 1500w
Its the PLUS model so the max pv charge is 60 amps
so 24V model is 1500 w (mine also)
and the 48v model is 3000w same as the 5KVA model
When i got the inverter last year the 48 volt 3KVA plus models were out of stock so i went for 24 volt
Cool are you uploading to emoncms
How many panels are you using?
Im using 6 Renesola vurtus2 255W panels got them for a good price from www.solarsolved.co.za in cape town but no stock at the moment.
2 strings of 3 panels runs at about 84v at max power
running my zodiac flow pro pool pump, geyser heatpump , all house lights and some plugs from a sub db fed by the inverter
I get around 1.1 kw midday from the panels currently, thinking of maxing the charge controller by adding another string of 3 X 255w panels.
It sould yes
There's guys in Australia that have hooked up 9 250W panels to a Axpert MKS plus 24V 3kva in 3 strings of 3 panels
if the output from the panels gets more than 1500W the MPPT controller will just take what it can it wont go over 60 amps.
Thanks to EDMUNDP im all set up :)  http://www.pvoutput.org/list.jsp?userid=50978
  • 3 months later...
