Solar Battery Cost Analysis
Gerald_db
The biggest problem with this is twofold: 1) Prices are generally tied to Rand/Dollar exchange and price on demand so it fluctuates a lot. And most suppliers have different levels of markup. Ideally this should be done with dealer pricing, or a set margin of say 10% to get an accurate table of costs.
Going to go with 2 x 8 x T105RE's. Most cost effective and cycled to 25% DoD should give me 10 years and hopefully by then new technology has killed the price of storage. Other option is 8 x T105RE's and just to kill them in 4 years or so and hope the lithium's have plunged by then.
@Manie. To use 1 bank of 48v and cycle hard and hope that there is a cost effective 20 year new generation battery in 3 or 4 years when they are tired or 2 x 48v strings that could ne good for 10 years or more is the decision to be made.
9 minutes ago, Gerald_db said:
... cost effective 20 year new generation battery in 3 or 4 years ...
My gut feel says 10-20 years, measuring against me saying same 5 years back.
I also simply do not see this happening. The "man" has too many vested interests in this not happening. [emoji85] [emoji86] [emoji87]
Sent from my SM-N900 using Tapatalk
Hi Gerald did you have a look at the lead crystals. I know it is expensive but you can get alot more cycles out of the batteries and its very save. You can cycle it alot deeper that other batteries.
I see at pv out that extra pannels makes a huge difference. Well done. What type/makes batteries do you have?
13 hours ago, Manie said:
Deltec
Careful. Cycle life on the Deltec is much lower than on the Betta Battery. Consult with the spec sheets. I may be wrong, but the last time I checked the Deltecs were somewhat disappointing, hardly doing much better than our benchmark Trojan :-)
9 hours ago, Manie said:
Seems Deltec is the better one
What numbers are you seeing? It's quite likely that I have the wrong end of the stick, this is just what I remember. I saw the price and cheered up, then I saw the cycle life and lost all that cheer. Let me see if I can find it again.
<insert Saxopohone music here>
Here we go... http://www.battery-pmp.co.za/Deltec-Lead-Crystal-Batteries.pdf
Page 5, second chart on the left. Around 1600 cycles to 50%. Same as Trojan T105RE.
<Insert more Kenny G here>
http://www.solarsolved.co.za/datasheets/batteries/Deltec/Lead_Crystal_6_CNFJ_200.pdf
Page 2, second chart down on the right. Around 3200 cycles to 50%. That's double.
If there is another spec sheet I should see, please send it to me. The above two are the reason I dismissed the Deltec as a possible option.
So basically, if you can get me 3000 cycles at less than 7k, the math is as follows:
12*200*0.5*3000 = 3600 kwh over lifetime
7000/3600 = Less than R2 a kwh (without even doing the math)...
If it can only do half that cycle life, then price is over R3 per kwh and lead acid wins.
Deltec is an official distributor of Lead Crystal batteries in South Africa. Instead of having a Betta Batteries label, they are re-branded to display Deltec's logo as they are an official supplier. Deltec's data sheet is however incorrect if I am not mistaken (they have been notified). Rather get your data sheets from the Lead Crystal website. You will also see Deltec's details under the Africa distribution link.
http://leadcrystalbatteries.com/distribution/distributors-in-africa/
