Rigolo Posted September 25, 2021 Share Posted September 25, 2021 Hi, I have an installation with 10 kW solar panels, 10 kW InfiniSolar hybrid and 3x Pylontech US3000C batteries. For monitoring I'm using ICC Solar software on a Raspberry. Generally, the system runs reasonable and is configured as "Grid-tie with backup (II)". he only thing is that I have a couple of questions regaring ICC Solar software, but I never received any response from them to the mails I've sent. Seems there is no customer support, also the manual is quite "lightweight", not providing any details . Therefore I would be happy if you could share any feedback Is there any possiblity to stop discharge of the battery at 25 % SOC, for example? Background is that I would have some buffer and never discharge the batteries completely. Besides that, it would also increase lifetime of the batteries. Is there any possiblity to limit charging to 90 %, for example? This would also increase the lifetime of the batteries. If found these settings, but it is not clear to me: "Info Log" shows these following messages. What does it mean? There is an option "Home Automation" to control relays based on different states (SOC, etc.). Does anyone have any information about the protocol / Commands used to control a relay board? I have plenty of Arduino boards and relays here which I want to use, don't want to spend money for any "special" boards. I assume these are rather simple commands. Regards, Matt Quote Link to comment Share on other sites More sharing options...
RudieB Posted October 28, 2021 Share Posted October 28, 2021 Replace ICC with Solar Assistant. It runs on your Raspberry PI. Check: https://solar-assistant.io/ Quote Link to comment Share on other sites More sharing options...
Rigolo Posted October 29, 2021 Author Share Posted October 29, 2021 I have seen solar-assistant already, but there is even less technical information available than for ICC. And it seems there is no possibility to control GPIOs by specific SOC or anything else. Quote Link to comment Share on other sites More sharing options...
