Pi running Solar Assistant periodically disappears off my network
Afternoon All,
Since starting with SA, I sometimes see that the Pi disappears off my local network. It usually does this for about 10 or 15 minutes and then returns by itself. Sometimes it will disappear for half a day and I try to reboot the Pi using the Bluetooth connection.
In all instances, no data is lost.
Any thoughts on what may be causing this? Is there something on my network that I can try and look at regarding the Pi connection?
I have contacted support at SA but they have no idea why its dropping off my network.
MdF
Easy test, run a cable for the network if you on wifi. Either move the PI to a different location, or run a temp cable to the router. In 2 or 3 days you should know if its wifi or not.
Morning All,
The Pi is connected via wifi to the router. Signal to wifi at the Pi is 3 or 4 bars.
No, the Pi is not connected using a USB adapter. The Pi uses its own inbuilt wifi to do this.
The difficulty with connecting the Pi to the router directly is the distance to the router - about 20m and not practical at this time. Will need some planning to do this.
Regarding interference from other hardware on the network - well, the Pi was off at 6am this morning with nothing by way of hardware being used on the network.
Some research on the interweb suggests that the Pi could have Power Management turned on and that it is going to Sleep at some point. A suggestion is for Power Management to be turned off on the Pi?
MdF
On 2021/10/03 at 2:32 PM, MdF said:
Afternoon All,
MdF
Hi MDF , if you connect your pi with keyboard and monitor , you can run a ping test from the terminal to your router address. You can set ping interval and optionally redirect output to a text file. You will soon pick up if the connection  is bad , jittery or even times out.   If it is bad , move your wife router to close proximity to your pi and redo the test. Soon you will discover if the IP transport level is your problem or not.
Thanks Dropkick.
Update:
So, whilst looking at ways of laying temp network cable yesterday, I happened to move the Pi about a meter from where it was currently sitting. It connected to the wifi immediately.
I have left it where it is for now and will see how the Pi runs for the next few days. This may simply have been the Pi being located in the wrong place 🥴
MdF
Here's something very bizarre I noticed about my Pi last week. I had my Pi right up against my battery cable connections to the inverter (this was during testing Solar Assistant). Noticed some strangeness - the Pi would occasionally do a boot loop, restarting itself and occasionally drop off the wifi connection. Moved it far away from cabling and it settled down. Chalked it down to some sort of magnetic interference - called it a day - and forgot I ever had the issue. :D
Was a weird one.
Was a weird one.
My Pi was sitting on top of the battery case close to the battery cables. Could have been "interference" as well 😲
Two things are important for WiFi comms and electronics in general. One is signal to noise ratio. In this case it may be that the interference from the Inverter & battery system could drown out the WiFi signal. The other issue is of EMI/RFI. If the PI is shielded (a metal type case), it will reduce or vastly reduce interference from outside and keep whatever the PI generate, mostly inside. Plastic cases not al all. If the WiFi antennal is still inside the metal case, it may reduce the WiFi signal and slow down the WiFi speed to boot.
There are lots of EMI/RFI around us, lightning generates a lot, digital device all generate a lot but at lower levels, some lighys may generate, chargers generate a lot normally so do induction stoves, microwaves etc etc.
So, having moved the Pi to this new position away from the battery and cables etc, the Pi has only "disappeared" off the system once in the past 3 weeks 😀
  • 3 months later...
I had the exact same issue with mine initially. So I moved it about a bit to find a "sweet spot".
It still does it about once or twice a month for a while but has been a lot more stable. There are two thick walls between the router and the Pi in the garage. By design the PI does not have a fantastic WiFi signal and with the antenna integrated in the board the signal strength is OK for close proximity only.
As said for now I am satisfied but I am still considering a Powerline WiFi extender where the slave could be on the same plug as the Pi.
They cost about the same what I paid for the Pi. Just need to find the spare funds for something that would be a nice to have for now
https://hackaday.com/2016/03/18/hacking-the-raspberry-pi-wifi-antenna-for-more-db/
Edited by zsde
34 minutes ago, Scubadude said:
Powerline adapters are a waste of money.  Use that money to buy a networking toolkit and a roll of cable and make your own cable.  May work out cheaper than powerline and guaranteed to work much better.
Agreed never really had luck with them.
Since I moved my Pi a while ago away from the batteries and cables etc, I have found "The Sweet Spot" and the Pi has only been offline once or twice in each month.
What I have noticed is that a reboot of the Pi (via Bluetooth) does not bring it back but rather a reboot of my home WiFi network fixes the issue.
So, still very happy with the system and how it is running.
During the last round of loadshedding, remote changing of Time of Use settings worked really well to allow me to make sure there was enough in the batteries for the early morning loss of power.
MdF
 Share
