TeddyBear Posted October 11, 2021 Share Posted October 11, 2021 Hi guys, I just bought a new hubble AM-2 battery and tried to connect them using the CAN ports as follows. My inverter doesnt read any info from the hubble BMS. I made a new cable as per their website here https://www.hubblelithium.co.za/sunsynk-hubble-setup.html with Pin 2 Being a green cable, Pin 4 being Orange and Pin 5 being Blue with still communication. I first used the Yellow cable that came with the deye and had no success and looked on their website and saw that layout. Any assistance would be appreciated inverter side Quote Link to comment Share on other sites More sharing options...
Iiceman Posted October 11, 2021 Share Posted October 11, 2021 Did you set an "address/dip switch" on the battery? Quote Link to comment Share on other sites More sharing options...
TeddyBear Posted October 11, 2021 Author Share Posted October 11, 2021 7 minutes ago, Iiceman said: Did you set an "address/dip switch" on the battery? Hi there, Nope all of them are in the "off" position (all of of them are on the side closest to the numbers) Quote Link to comment Share on other sites More sharing options...
Iiceman Posted October 11, 2021 Share Posted October 11, 2021 1 minute ago, TeddyBear said: Hi there, Nope all of them are in the "off" position (all of of them are on the side closest to the numbers) if you only have 1 AM2, then move dipswitch 1 to "ON", rest remain OFF YellowTapemeasure 1 Quote Link to comment Share on other sites More sharing options...
TeddyBear Posted October 11, 2021 Author Share Posted October 11, 2021 6 minutes ago, Iiceman said: if you only have 1 AM2, then move dipswitch 1 to "ON", rest remain OFF Thank you. I will try this when I get home and relay any updates. Iiceman 1 Quote Link to comment Share on other sites More sharing options...
TeddyBear Posted October 12, 2021 Author Share Posted October 12, 2021 23 hours ago, Iiceman said: if you only have 1 AM2, then move dipswitch 1 to "ON", rest remain OFF Hi there. This worked! Thanks so much Iiceman 1 Quote Link to comment Share on other sites More sharing options...
Iiceman Posted October 12, 2021 Share Posted October 12, 2021 16 minutes ago, TeddyBear said: Hi there. This worked! Thanks so much No problem, glad its sorted out.. TeddyBear 1 Quote Link to comment Share on other sites More sharing options...
new2solar Posted October 14, 2021 Share Posted October 14, 2021 Will it work with a normal network cable from the CAN of the battery to the CAN of the inverter? Quote Link to comment Share on other sites More sharing options...
Iiceman Posted October 14, 2021 Share Posted October 14, 2021 15 minutes ago, new2solar said: Will it work with a normal network cable from the CAN of the battery to the CAN of the inverter? yes correct, CAN cable is a regular network cable.. Quote Link to comment Share on other sites More sharing options...
new2solar Posted October 14, 2021 Share Posted October 14, 2021 Thank you Iiceman 1 Quote Link to comment Share on other sites More sharing options...
