1ougat Posted October 17, 2021 Share Posted October 17, 2021 Hi As you cannot run a generator through a parallel setup on a Sunsynk inverter - how do you suggest I connect the generator ? It is for a home setup that the use of the generator is for the rare occasions that the load-shedding is long and the batteries are depleted and it is used as the ultimate backup . I already have a change over switch between the inverters and the main . Install another change over switch on the mains input of the existing change over ? Contactor? Relay? Your thoughts would be appreciated. Quote Link to comment Share on other sites More sharing options...
