BattleNan8404 Posted October 25, 2021 Share Posted October 25, 2021 Hi I have an Axpert 5kw 450VDC Inverter with only three battery options. Is there a way that we can update the firware to newer version with better options like PYL,WEC,LIB ect Thank You Quote Link to comment Share on other sites More sharing options...
0 Coulomb Posted October 25, 2021 Share Posted October 25, 2021 2 hours ago, BattleNan8404 said: Is there a way that we can update the firmware to newer version with better options like PYL,WEC,LIB etc. Only if you have a model with a removable display. Those battery type options require the ARM processor, firmware, and hardware that is not present with the models that have a fixed display. Quote Link to comment Share on other sites More sharing options...
0 BattleNan8404 Posted October 25, 2021 Author Share Posted October 25, 2021 Thanks it is a Mks II inverter non removable front. so the Pi would be the best option to use Quote Link to comment Share on other sites More sharing options...
0 JoeyhZA Posted October 26, 2021 Share Posted October 26, 2021 For Solar Assistant you can get it running perfectly on a Pi Zero at a fraction of a Pi4 or even Pi3 cost. Quote Link to comment Share on other sites More sharing options...
Question
BattleNan8404
Thank You
3 answers to this question
