Posted November 13, 20213 yr I have a problem with kodak inverter OG5.48. When I connect solar panel only without connecting to the grid. The inverter indicates 32 ⚠️ and no battery connection while battery is connected of 12V. But when I connect it to the grid without batteries and panels. The 32 ⚠️ is not appearing. Please guys help Or whatsapp me on 081 467 7244 it's urgent
November 13, 20213 yr 2 hours ago, Bryan95 said: while battery is connected of 12V Surely a typo? If not, as @Buyeye said, this inverter needs a 48V battery. Disconnect it asap, the battery might be already ruined. Edited November 13, 20213 yr by Calvin
November 13, 20213 yr 1 hour ago, Bryan95 said: You make your battery 48 volts by connecting four 12 volt batteries in series if you are using lead acid or gel. If you are using lithium then it's best to use a 48 volt battery. Edited November 13, 20213 yr by Buyeye
