A few calculations for an inverter
Did my home and I think it is right ... thought I would share to see if I got it right.
I want to install and inverter only ... no solar (online type ... maybe a mecer king would be a good selection)
The inverter will be used as a backup system for an office.
The installation:
AC mains
230 VAC
18 amps (a constant 18 amps load ...measured)
4140 watts
backup time required ... about 3 hours.
DC section:
4140 / 0.7 = 5914.28/ 1000 5.9 KVA  (an 8 kva would be required)
0.7 used for inverter losses.
48 VDC
86.25 amps
for a 3 hr backup rounded to 90 amps x 3 = 270 Amp/hr
The customer will be supplying the batteries and he want s lead acid ... so we need to divide the amp/hr 0.5
270/.5 = 540 Amp/hr
If we were looking at lithium then it would just be the amp/hr x VDC
270x48= 12960 w/hr divided by 1000 = 12.96 kw/hr battery.
Selection:
1 x 8 kva mecer king in inverter
3 x 5,5kw/hr batteries
I also considered a 3 phase inverter ... but decided to stick with the single phase to keep it simple.
