Posted December 4, 20213 yr OK so this may be really basic ... but with loadshedding just announced I'm a little uncertain what to do with my new system ... We will be hit between 4 and 6am tomorrow morning, so pleanty of time to prepare. Luckily I heat up both geysers to 65° earlier so no worries about warm showers. After everybody have been full-body santised, I'll switch the geysers off to avoid the early morning pre-heating I do on the solar geyser (the other one is normally hot enough in the mornings). More importantly, I need to adjust my battery profile ... I normally discharge to 20% over night, and by 4am I'd be lucky to have much more than that left. So I'm thinking to enable grid charge from midnight, and charge up to 100%. But then again I may as well enable grid charging now and keep it full until required? Or maybeI'm being completely paranoid ... I will wake up with an almost full battery, losing out on some of tomorrow's production. I have 10kWh at 77% right now. So I will adjust the minimum SOC for the night to 50%, leaving me with at least 30% (3kWh) when Eskom goes down ... should be plenty. Makes sense, right?
December 4, 20213 yr What i found is when loadshedding occurs at that time(early morning) i usualy dont have to change any settings as when the grid is off you wont be supplementing the non essentials so you should be using a bit less power than normal from the battery.
December 4, 20213 yr Sound like you have a SunSynk - same as me - also my first time. I like the last idea of setting the SOC to 50%, so when you hit 50%, the inverter will use grid. When load-shedding starts you will have go from 50% to 10% shutdown. The load shedding is ~2 hours, so 40% (50-10) should be enough - you then have until the next load shedding cycle to charge from PV, Thanks in advance to any more experienced/knowledgeable users who can guide us. Edited December 4, 20213 yr by system32
