Raj35 Posted December 14, 2021 Author Share Posted December 14, 2021 35 minutes ago, Gnome said: Heh, no problem, I'm more interested in how it's going, its your project I had the same problem. I don't have kids so I was able to work on weekends, but making my own busbars basically took almost an entire weekend of productive time from me. Theoretically it is all really quick and easy, practically each small little detail takes time. Did you weld that stand yourself? My welding skills are near non-existent but I'm thinking of dusting off the old welder and trying to build a metal enclosure. Alternatively I also have some Aluminium brazing rods and thought I might try to make an Alu enclosure using brazing rods. Hi I did weld that myself between playing with my 4year old and escaping into my lair while she asleep I sat till the am sorting this out. Quote Link to comment Share on other sites More sharing options...
Raj35 Posted December 14, 2021 Author Share Posted December 14, 2021 JoeSlow 1 Quote Link to comment Share on other sites More sharing options...
Raj35 Posted December 14, 2021 Author Share Posted December 14, 2021 Quote Link to comment Share on other sites More sharing options...
Raj35 Posted January 23, 2022 Author Share Posted January 23, 2022 (edited) After 39 cycles battery is performing very well, get close to 14kwh from it cut off voltage 49.5v no stress on them. Edited January 23, 2022 by Raj35 Gnome, P1000, ibiza and 1 other 4 Quote Link to comment Share on other sites More sharing options...
Clynton Posted July 15, 2022 Share Posted July 15, 2022 On 2021/12/07 at 7:49 AM, Gerlach said: If you guys are looking for 280ah lifpo4 sells and JBD bms, I got someone that imports local. Jaco is importing direct from the manufacturer. 2nd shipment is on it's way. There is already a bunch of this bms floating around in SA that he have imported and sells. Hi Gerlach. I've been looking for EVE LF280K cells and they're currently as scarce as hens teeth. I'm in Cape Town, anyone you could recommend for a local purchase that actually has stock or will be getting within the next 2 weeks or so? Quote Link to comment Share on other sites More sharing options...
