Posted December 16, 20213 yr Hi all. I have installed a Sunsynk 8.8kw with 2 x BSL BATT 5.1kwh batteries in parallel. One master and the other slave. Connected the battery link cables and the CAN cable between the master battery and inverter . But I can't see the BMS info on Solarman . No PV installed on this system. Just a back up. I connected up a 3P 12kw Sunsynk recently with 3 Hubble 5.5kwh batteries in parallel in the same way and can see BMS info on Solarman. Pv installed on this one. 24x 455w panels. 3 arrays as the Sunsynk has 3 MPPTs. Please help. Below are screenshots of the Solarman app for both inverters.
December 17, 20213 yr Same thing here. I have done 3 installations with 5kW Sunsynk and Shoto 5.2kWh using battery voltage to set the parameters. But it's not showing battery. Maybe the app is malfunctioning.
