Total newby here with next to zero knowledge of any form of electrical systems.
What I have:
  • 7.2 Kw inverter
  • 5.1 Kw lithium iron battery
  • 1620 W of solar panels
Typically the solar panels will supply (on a sunny day, of course) between 30 and 40-something % percent the active power used by the house. Example right now: House usage at present is 218 W, input from panels is 99 W. The battery is fully charged (and priority is set to 1=solar 2=grid and 3=battery).
My question is: should the solar panels not provide a figure closer to 100% of the active power usage (assuming enough sunlight available)?
Thanks in advance.
What is your daily average of power produced by the panels?
Most people get about 4 X Installed PV in Winter and 6 (max) x PV installed in summer (provided there's no rain, of course).
If you're getting that total spread over the day then its about right.
What I have:
  • 7.2 Kw inverter
Thanks in advance.
So it sounds like maybe that is because your inverter is drawing a small amount of power from the grid (to prevent feed in to the grid). What inverter do you have.
Not sure. The figures I quoted is real-time.
The panels are (as I understand it) capable of 1300+ Watts (3x 540 W). I'd like to establish if the panels can, theoretically, provide enough power to not draw from Eskom (during the day).
Edited by Tinmug
I have a Kodak 7,2 Kw off-grid inverter.
What I have:
  • 7.2 Kw inverter
Thanks in advance.
Hi @Tinmug, that sounds about right. The Axperts inverters with AC power blending  will always mix in a bare minumum  amount of grid power with solar and that is in the order of 100watt. According to @Coulombit is done in order to do with stability and to disallow power to be inadvertantly being exported to grid during the mixing-blending function.
If you remove grid , you will see the solar takes over that 100w , in addition to the internal system requirement.
So your inv is functioning correctly.
Edited by dropkick
Fantastic, thank you very much for confirming. 👍
