January 24, 20223 yr 2 hours ago, JohanG said: Can one incorporate a 24v lithium battery into a 48v setup.😕  You will need 2 as pointed out, but you also need to make sure the battery supports series. Internally Lithium batteries have BMS which has a maximum voltage rating. So it is critical to ensure the product documentation indicates that BMS support series operation.
January 24, 20223 yr 3 hours ago, JohanG said: so no easy way🙄 What were you hoping for? Turning a single 24v battery into 48v?
January 24, 20223 yr 56 minutes ago, JohanG said: Bingo🙂 Yeah sadly no, unless you rip the battery apart. Which means you spent a bunch of money, lose your warranty, need to probably buy a new BMS (R2-3k) and then put it all together which is actually quite a bit of work.
