Sunsynk 5kw - Considering 800W/12v Victron Inverter on Generator Port?
Currently running a
  • Sunsynk 5Kw Inverter and
  • 5Kw BSL battery and
  • Its fed by 4.5 kw Panels facing North on a Flat roof
  • Typical Config is feeding Essential DB Circuit and rest of DB via backfeed and Ct Clamp Monitor
  • In the mornings I end up with 60% Battery Power Left and my typical consumption is 1000 kw per month, 30kw ish per day of which I buy 25%
Als have a mostly unused ready to go Camping/Backup/STHF Inverter setup worth almost 20k
  • 800W/12v Phoenix Inverter
  • a DIY LithiumSA 12V Lithium Battery Bank with BMS (8 Cell 120A), thus about 2.5kw and Bluetooth Kit
  • a Victron 100/20 MPPT
  • 1x 290W Roof based Solar Panel topping up the battery on its own
  • 12V 20A 3, port 12v Victron Charger (Offline)
  • I also have 2x 160w panels (top one Active) on my 4x4 with 1 Extra High Cycle Battery running a Ctek Vehicle Solar Charger
    • This is handy for camping
Question:
  1. Will it be wize to feed my Victron 800W/12v Phoenix Inverter on the Generator Port
  2. Benefits I can count on ?
  3. How to configure ?
  4. If I can adjust my seconday camping setup, what should I do?
  5. Other advice ?
Hope I can get some advice, thanx in advance..
  • 4 months later...
