February 4, 20224 yr Hi I'm wanting to run 2 laptops and 2 computer screens and a router in my home office. I just bought the Mecer 2400W inverter. Now trying to decide on batteries. What 12V batteries would you order and where? (I need 2) Is there a difference between the various brands? How long are they likely to last? I hear things from 1 to 4 years, but would prefer someone who's done a small setup before. Or would you go for a Lithium Ion but go for 2 smaller amp hour ones due to the cost! (I don't need much load - see above) Really appreciate the input! Thanks Alex
February 4, 20224 yr Hubble S-120. For two in series you will need an external battery balancer though. I have deployed the older Hubble S-100 with the Mecer 2400VA inverter before, they work well together.
February 4, 20224 yr 4 hours ago, YellowTapemeasure said: Hubble S-120. For two in series you will need an external battery balancer though. I have deployed the older Hubble S-100 with the Mecer 2400VA inverter before, they work well together. Agreed. I have replaced a friend's lead acid with the 2 x S100 and a 24V Hubble balancer and he loves the performance.
February 24, 20224 yr On 2022/02/04 at 1:13 PM, YellowTapemeasure said: Hubble S-120. For two in series you will need an external battery balancer though. I have deployed the older Hubble S-100 with the Mecer 2400VA inverter before, they work well together. Just be carefull when using a Victron battery balancer. They only start to balance at 27.3V and stop at 26.6V I have found my 2 x S-100 never charges to higher than 27-27.2V. Then as the Victron balances at 0.7A not much balancing might take place by the time the batteries reaches 26.6V=13.3V per battery. After 3 months of use my S-100 are staying within 0.1V of each other and mostly at the same voltage.
March 11, 20224 yr 1 hour ago, AlexanderR said: Are there any lead acid batteries you guys recommend? Some people are happy with Royal 1150K but I like Raylite Excis as the can be deep cycled now and again. These 2 are budget range being non Gel. Great for LS
April 17, 20224 yr Author On 2022/02/04 at 1:13 PM, YellowTapemeasure said: xternal battery balancer though Do you have one you'd recommend?
April 19, 20224 yr On 2022/04/17 at 7:25 PM, AlexanderR said: Do you have one you'd recommend? A Victron balancer would be in the region of 1K. The person in the best position to answer that question would be Steve from the Powerforumstore, he knows what works and what doesn't, and what cost-effective hacks can be done instead of using a balancer (like swopping the two batteries around, for example).
