Posted February 5, 20223 yr I have a unpleasant situation with 2 MPIP 8048 connected in parallel and having 8 Pylontech. The issue is even the setup for Max Ac Charging is set to 2A and Charging Source Priority is set OSO, the inverter start after 7 o'clock in the morning to charge from grid with the setting of Max Charging Curent wich is about 90A and this is means 40A per inverter.....anf settings for both inverters is Charging ONLY from Solar and AC Charging is set to 2 Amps.... I'm really disappointed with these because every morning I'm disconnected from grid based on max curent allowed (32Amps), Is there a similar situation that happened to someone here? Do you have any ideas for what to do? PS Al equalization function are disabled!I have corelate one thing with this...at this time the panels start to generate some watts..20..30watts, Edited February 5, 20223 yr by vulcanescu35
