Install solar asstant on the pi. I think it costs R900. Make sure you have the version that support the 3 phase inverter. I had to install a beta version. You will need a console cable from the pi usb to the console port on the battery. I use pylontech batteries. You need a rs485 cable from the pi usb to the bms port for each inverter. I bought the cables from sunsync.
It works quite well.
  • 5 months later...
On 2022/02/08 at 2:55 PM, Chris Jensen said:
Hi All
Hope someone could help me in my confusion to connect a Raspberry pi 3b+ to my inverters
I have 3 x 3phase 12kw deye inverters connected in parallel. Rj45 cables come from the bms port of each inverter to a rs485/can hub and then to my master battery.
So my question, how to connect the raspberry pi?
Inverter model number : sun-12k-sg04lp316443283715439214927691614369484.thumb.jpg.75926283469d6fd4ba13a7d02ca359de.jpg
How did you solve the connection problem ?
Have same problem with Deye SUN-10K-SG04LP3 where Meter Port is used for Eastron Smart meter and BMS used for connection with Pylontech.
Hi Jaxone
Well I'm not an installer but what I did is I used the meter port of each inverter to the raspberry.
I'm not sure if a rj45 splitter would be your answer to connect two devices on the meter port.
I while ago I read somewhere that if you upgrade your inverter to the newest firmware you could use the bms port for solar assistant as well.
 Hope it helps.if you struggling with the cable between inverter and raspberry i would send some photos of the connection.
