Posted February 9, 20223 yr Hi all I recently was going to by a Solis inverter but the advised I would need a Vitron inverter for the battery pack. Therfore I am now looking at the Deye 12kw inverter I wanted to confirm that the inverter will supply all 3 phases from solar even though the phases will not be Balanced or will it only supply the lowest demand phase. For example phase 1 and 2 are drawing 5kw and phase 3 is drawing 2 kw. Will the inverter supply this load or all at 2kw with the extra demand fed from the grid?
February 10, 20223 yr If it is the same as the Sunsynk, you can do 6kW on one phase (while doing 0 on the other). Or any mix where the total is less than 12 and the max on one phase is less than 6.
February 10, 20223 yr 15 hours ago, Deeos said: I recently was going to by a Solis inverter but the advised I would need a Vitron inverter for the battery pack. This is interesting, can Solis not work with battery? 15 hours ago, Deeos said: Therfore I am now looking at the Deye 12kw inverter I am also looking at three phase units but paralleling a few units if possible and am also interested in the Deye or something reliable. Do you know what Deye support is like?
February 10, 20223 yr Author Solis have stated the 30kw model would not work with batteries unless you use a battery charger. They will have one that will do this in the 3rd - 4th quarter of this year. I'm going to go with the Deye 13kw for my house and eventually add another unit when I can afford it. I dont want to have a complexed system. My ac on full load will draw 25amps 3 phase so I cannot run this for now.
