ICC LXTerminal error on Pi 3 B
I've installed the Jessie/Pixel image preloaded with ICC installed, downloaded from your website and am running it on Rpi 3 B. I am getting error messages in the LXTerminal window, which hangs on this repeated message. However, ICC seems to load OK and is displayed. Maybe the error is just coming from the fact that I haven't yet plugged the usb from the inverters into the Raspberry? If I close the LXTerminal window it shuts down the ICC App (which may be normal behaviour).
If it helps, this is the look of the desktop on initial power up of the Pi.
Yes we all do , this is a GUI, we had a discussion on a previous forum. The app however runs fine !!
The app also needs to be registered as it will not make difference if you plug in the inverter to it.
I see, so this is normal behaviour. How do I register the app. Do you need the machine number that appears in the "Settings"?
