Posted (edited)
Good day
Ok so I recently decided to go solar
Installed Kodak 7.2 Max inverter
16 x 410w Canadian solar panels pointing North at about 30 degrees for tile roof angle
8 per string on each inverter input
Currently only have 4.8kWh battery installed
But will be going 15kWh
One issue I am getting is the panels seem to be maxing out at about 3.2kW maximum
They appear to be giving out about 50% of the listed power
Can someone advise what could cause this?
I specifically make sure that the used power to charge the battery and used beyond that is higher by fair margin above what is coming in
I know that if my required usage was only 3.2kW then the inverter would not push above that
Edited by Veneficus
Posted (edited)
Voltage on each string goes up to average 270-280V
When about 1.6kW per string is provided the unit sits at about 220v
The 2 strings is connected to PV1 and PV2 inputs
Edited by Veneficus
