Repeated input values in emoncms
I've set up an input from ICC to a local emoncms running on the same Raspberry Pi but I am getting pages and pages of inputs with repeated values for all the measurements. Is this correct or have I done something wrong? In ICC I used the "write" API Key to submit the data - is that the problem (should I have used the read API Key?
If you look at the your attached image, I don't know where that feeds is coming from. I post to node 1 and there is no issues there
Hi. That's what I thought. For some reason it created the new node. All I did was put in the emoncms URL and the API keyy in ICC and then check the "Post Data" box. When I went into emoncms it had created that new node where it repeats the feeds hundreds of times. Any ideas why?
What does node one shows?
It seems to be showing as it should with no repeated data fields but posted data does not go there, it goes to the new node (that has no number and seemed to be created when I first posted to emoncms). There are some values for some fields in node 1 but I'm guessing that is just from the original Jessie/ICC image creation. All show as "inactive".
Yes is may be . Delete it and let the app send the inputs
Just now, Manie said:
Yes is may be . Delet it and let the app send the inputs
I cannot find any way to delete a node. If you look in the inputs config in emoncms you can delete individual fields in a node but there are no options to delete the node.
Stop sending data to emon and start deleting the inputs one by one. If you delete the last input then the node will be deleted. You cant delete a note if there are still inputs in that node
OK, that worked - there must have been over 1,000 feeds in there all repeated, but when I deleted the last one it also deleted the node as you said. I'm going to start again and hope that this time it works. Just to check - in ICC the API key I need to use to post data is the "write" key, right? That isn't what caused the problem?
yes you need the write key. Not sure because i am getting only one input as to my above attachment
OK, I know the problem. Sorry, all my fault. The data was coming in from the old installation of AICC that I had running on Windows. I imagine that is not set up correctly to work with the new setup of the emoncms server on the RaspberryPI
It can be . I don't support AICC for windows and can not comment on it. Still a great app to use for serial comms !!
Yes it is - great app. Sorry about the mix up. I imagine that is what caused the problem in the emoncms feeds on the Raspberry Pi. I'm going to try now with the new ICC, but I've sent you a PM because the Key you sent isn't accepted.
I'm sending you screenshots of the license key error here as I can't attach them to the PMs.
