Can connection on 5.5, 8 kw Sunsynk inverter.
A question that came up !!!
Is the can connection (pin out) the same between a 5.5 Kw synsynk inveter and  8 kw Sunsynk inverter. I am not naming any battery suppliers but they say that the monitoring is working on the 8 kw inverter and not on the 5kw inverter. Any truth in this statment.
CJ
this doesn't sound right to me... I would think that both variants should should understand the same battery types...
from what I can see pin 2 on the CAN bus RJ45 is ground, and pin 4 is CANH and pin 5 is CANL, this seems to be the same for both the 5 and the 8kW Sunsynk inverters...
Posted (edited)
Ignore my previous post.  I was using inverter pinouts from the training manual.
The manual that came with the 8.8kW unit has the following for the pinouts:
2 - GND
4 - CAN-H
5 - CAN-L
I have made a cable for connecting the Inverter to my Pylontech US3000C and this is what is needed.
Inverter to Battery
2 to 6
4 to 4
5 to 5
Tested and working correctly.
Edited by billy
Incorrect information given
