Mark1981 Posted March 29, 2022 Posted March 29, 2022 Hi, I just had a quick question. I currently have a 1000W Axpert inverter that I am using a rasberry pi via the USB Type B port and python script to communicate with the inverter and do a bunch of things for me. I was looking at upgrading my system to an Axpert King. I just wanted to find out if they come with the same port and communication protocol for me to call the QPIGS function as I am currently doing? Quote
Coulomb Posted March 29, 2022 Posted March 29, 2022 6 hours ago, Mark1981 said: I just wanted to find out if they come with the same port and communication protocol for me to call the QPIGS function as I am currently doing? It's quite similar. I think that there may be some more fields at the end of the King's QPIGS response, but basically the same. I believe you'll have little trouble updating your software; it may even work without any modifications. Quote
Mark1981 Posted March 29, 2022 Author Posted March 29, 2022 7 minutes ago, Coulomb said: It's quite similar. I think that there may be some more fields at the end of the King's QPIGS response, but basically the same. I believe you'll have little trouble updating your software; it may even work without any modifications. Thanks very much. I also wanted to confirm if the USB port will work. They seem to now come with a Micro USB that is used for updating firmware. Will the USB port also still work for communication with the Pi? Quote
Coulomb Posted March 30, 2022 Posted March 30, 2022 On 2022/03/29 at 10:18 PM, Mark1981 said: Will the USB port also still work for communication with the Pi? Sorry, I don't know the answer to that. Can any owners confirm? Quote
