Kilowatt Power Posted March 30, 2022 Posted March 30, 2022 (edited) Greetings, I have a Deye 5K hybrid inverter model SUN-5K-SG03LP1-EU and the lights always dim slightly whenever it goes into island (UPS) mode. Question: Is there any way to set the output voltage to at least 230Vac instead of the 218Vac that I'm seeing across the load terminals? The grid voltage in my part of the world is 240Vac and I can't see any option to set the load output voltage to 240V Single Phase in the Grid Setup menu. Edited March 30, 2022 by Kilowatt Power Quote
Yellow Measure Posted March 30, 2022 Posted March 30, 2022 39 minutes ago, Kilowatt Power said: Greetings, I have a Deye 5K hybrid inverter model SUN-5K-SG03LP1-EU and the lights always dim slightly whenever it goes into island (UPS) mode. Question: Is there any way to set the output voltage to at least 230Vac instead of the 218Vac that I'm seeing at the load terminals? The grid voltage in my part of the world is 240Vac and I can't see any option to set the load output voltage to 240V Single Phase in the Grid Setup menu. My 5K Sunsynk does the same, my cooler fan runs slightly slower, drops a note, and the piezo starter on my stove pulses slightly slower. I am grateful for the electricity though, and it's not a total disaster, but it is noticeable. Quote
TimCam Posted March 30, 2022 Posted March 30, 2022 (edited) I Don't have the latest software, but I believe the SunSynk output Voltage can now be set. Maybe contact Deye support, as the hardware is the same, and they too might have an updated firmware to adjust the output Voltage soon. Edited March 30, 2022 by TimCam Kilowatt Power 1 Quote
Kilowatt Power Posted March 30, 2022 Author Posted March 30, 2022 10 minutes ago, YellowTapemeasure said: 5K Sunsynk does the same Noted. We can only hope that the manufacturer will one day provide a fix through a firmware update. After all function 08 on Voltronic Power Axpert MKS II 5K-48 did exactly that. Quote
Kilowatt Power Posted March 30, 2022 Author Posted March 30, 2022 16 minutes ago, TimCam said: I believe the SunSynk output Voltage can now be set. Maybe contact Deye support, as the hardware is the same, and they too might have an updated firmware to adjust the output Voltage soon. Excellent news. Requesting a firmware update right now. Thanks. Quote
