MQQT registration info
7 minutes ago, cvzyl said:
Machine ID is generated by the the software. You need to send it to Manie, he will generate a license key for you. Similar to ICC app.
Thanks. I imagine @Manie will see this. Please also let me know the port that I need to use with the IP. From what I understand the MQQT Windows App connects in to the MQQT "server" running on the Raspberry Pi. So I know the IP of this but am not clear which port that MQQT "server" uses. Also, if it is a special port, will I need to set up a firewall rule in the Raspberry to open it on the Raspberry? At the moment I am running MQQT Windows App on the local network with the Raspberry.
11 minutes ago, Manie said:
Look at the pi settings. There is a place for mqtt and the port number
The MQTT is great by the way. It means that normally you don't even need to worry about remoting in to the pi where ICC is running. For monitoring all I need to do, then, is just run this app. I will only need to remote in to the pi if I need to change mode or other settings. Makes a great add-on to ICC.
5 hours ago, Manie said:
Is the data coming through on the pi?
I now have the data coming through into ICC on the pi. I connected the USB to the "slave" Axpert inverter in the cluster and it works, as @Don mentioned. The only thing that doesn't seem to be configured correctly is the Emoncms feed. The Emoncms server is running on the same pi (not sure if that is a best practice) so it is localhost. In the settings tab in ICC I have entered the Emoncms API key and for the host "http://localhost/emoncms" but that is obviously not right as it doesn't send the data. Should I be using "http://127.0.0.1/emoncms" or something else?
2 minutes ago, Don said:
Just enter the following under Emoncms Server : localhost/emoncms/ (without http)
Thanks, trying now ....
OK. That works - noteworthy that the trailing forward slash at the end of the address is required (not always the case).
Edited by incagarcilaso
Update.
