Rudolfs32 Posted April 9, 2022 Posted April 9, 2022 Kindly advise? What should the lowest battery discharge setting be and why? 10%? 20%? 30? Quote
0 Scorp007 Posted April 12, 2022 Posted April 12, 2022 On 2022/04/09 at 5:43 AM, Rudolfs32 said: Kindly advise? What should the lowest battery discharge setting be and why? 10%? 20%? 30? This you have to decide. Some margin left for when there is LS like now up to when the PV kicks in. Quote
0 Dyness Posted April 13, 2022 Posted April 13, 2022 Hi there.The cut-off value of the battery is recommended to be set to 20%, and the minimum can be set to 15%.Thank you. Quote
0 Farhaan Posted April 15, 2022 Posted April 15, 2022 Hi. What is the voltage cutoff which translates to 15%? Quote
0 Dyness Posted April 24, 2022 Posted April 24, 2022 On 2022/04/15 at 12:41 PM, Farhaan said: Hi. What is the voltage cutoff which translates to 15%? 46V minimum. Quote
Question
Rudolfs32
Kindly advise?
4 answers to this question
