BSLBATT Posted April 14 Share Posted April 14 Test Quote Link to comment Share on other sites More sharing options...
WannabeSolarSparky Posted April 14 Share Posted April 14 Yes please, you can send to me and I will gladly test one. Currently unhappy with my 2 Narada's, they don't talk "Sunsynk" PM for address Nexuss and TimCam 2 Quote Link to comment Share on other sites More sharing options...
TimCam Posted April 14 Share Posted April 14 2 hours ago, WannabeSolarSparky said: Yes please, you can send to me and I will gladly test one. Currently unhappy with my 2 Narada's, they don't talk "Sunsynk" PM for address One is never enough, you need at least two, so that you can check the comms between the batteries and the inverter. WannabeSolarSparky 1 Quote Link to comment Share on other sites More sharing options...
WannabeSolarSparky Posted April 14 Share Posted April 14 (edited) @BSLBATT Seriously though, it would be interesting to see/do a side by side comparison. These Narada's have really good power output and talk well to each other and maintain a good balance. All that's missing is the chat with the inverter, I am too lazy to write some code to make that happen. Never too lazy to test some batteries in "real world" continuous loads. I run 780 watts continuous 24/7 and the narada's seem to be holding up nicely. How would the BSL's do with continuous full cycling? 100% to 10% and back up to 100% daily 24/7? Edited April 14 by WannabeSolarSparky Quote Link to comment Share on other sites More sharing options...
BSLBATT Posted April 15 Author Share Posted April 15 15 hours ago, WannabeSolarSparky said: @BSLBATT Seriously though, it would be interesting to see/do a side by side comparison. These Narada's have really good power output and talk well to each other and maintain a good balance. All that's missing is the chat with the inverter, I am too lazy to write some code to make that happen. Never too lazy to test some batteries in "real world" continuous loads. I run 780 watts continuous 24/7 and the narada's seem to be holding up nicely. How would the BSL's do with continuous full cycling? 100% to 10% and back up to 100% daily 24/7? Lithium battery comparisons are quite fun and reveal a lot of 'real' world information. We are happy to receive any Narada batteries and put them into our simulated testing environments. We would do a cycle test and capacity test on them. Principally we understand that BSL batteries will hold up longer, meaning they will allow 90% DOD for longer years. BSL lithium batteries have been extensively tested by Victron and Sunsynk to which they are globally recognised. Victron BSL approval: https://www.victronenergy.com/live/battery_compatibility:bsl Energy-Jason 1 Quote Link to comment Share on other sites More sharing options...
Sc00bs Posted April 15 Share Posted April 15 A question please @BSLBATT How much shorter a life should I expect from my BSL batteries if I discharge to 10% instead of 20% capacity? Thanks Quote Link to comment Share on other sites More sharing options...
BSLBATT Posted April 15 Author Share Posted April 15 2 hours ago, Sc00bs said: A question please @BSLBATT How much shorter a life should I expect from my BSL batteries if I discharge to 10% instead of 20% capacity? Thanks Your looking at around 3000 cycles / 7 years Quote Link to comment Share on other sites More sharing options...
Sc00bs Posted April 15 Share Posted April 15 @BSLBATTInstead of @ 20% ? Quote Link to comment Share on other sites More sharing options...
BSLBATT Posted April 16 Author Share Posted April 16 current warranty is set to 4000 cycles @ 80% DOD / 10 years Quote Link to comment Share on other sites More sharing options...
Sc00bs Posted June 6 Share Posted June 6 Hi @BSLBATT Lithium Are you batteries all compatible with each other? I have 2 x B-LFP51.2V 120ah batteries and would like to know what, if any other models, I could use if I want to upgrade my capacity. Not sure if you have a compatibility sheet of some sorts maybe? Thanks Quote Link to comment Share on other sites More sharing options...
