Got a GeyserWise Max with vacuum tubes installed about 2 weeks ago and have noticed that the element icon flashing after the geyser reaches 55c, but my max is set to 65c. Any ideas or thoughts?
Make sure that 65 is set throughout the week including weekends
It's been set as follows:
Monday > Friday
Morning: 55
Evening: 65
More showers in the evening than in the morning
Saturday > Sunday
Morning: 55
Evening: 65
I'll try it out to set block 1 and 2 (only use those two blocks) all to 65 and check
Monday > Friday
Morning: 55
Evening: 65
Saturday > Sunday
Morning: 55
Evening: 65
That should do it
56 minutes ago, grant.cpt said:
Thank you! Setting block 3 and 4 to 65c fixed it, even though it's not programmed to any times
Great stuff
The temperature blocks don't correspond to the 4 times that you can program. See the extract from the Geyserwise manual below:
1179512214_Screenshot_20220420-232650_AdobeAcrobat.jpg.3fd088630fa4a1de634501809625c6a6.jpg
If you trying to set block 3 and 4, change the time to 00:00 - once it reaches this time press the "up" button - it will then display --:--
Then the Geyserwise will disregard those blocks.
