HanroS Posted April 20, 2022 Posted April 20, 2022 I would like to knkw is there a setting I can change or do anything to thisninverter for it to use the batteries as last priority instead of the 3 Settings you can use it as is I want to use my Solar to supply the house and charge my batteries at the same time and if there is inadequet solar charg my batteries from the grid but I don't want to use my batteries at all just during loadshedding Quote
Steve87 Posted April 20, 2022 Posted April 20, 2022 Setting number 1 set to USB... Setting number 11 set to 20A or more... Setting number 16 SNU... The explanation is the following: setting 1 is the mode priority setting. The first 2 will be used and the last one as the standby. U= Utility, S= Solar and B= Battery Setting 11 is max utility charging Amps. Setting 16 is charging source. SNU means solar and utility simultaneously. So on a bad weather cloudy day, you will want setting 11 quite high to charge your battery from the Grid. Quote
HanroS Posted April 21, 2022 Author Posted April 21, 2022 It seems my inverter doesn't have USB in setting 1 only Uti, SOL, Sbu. Do I need to update my firmware or is there something else I could do? Quote
Coulomb Posted April 21, 2022 Posted April 21, 2022 5 hours ago, HanroS said: It seems my inverter doesn't have USB in setting 1 I believe that's a typo; it should be SBU. @HanroS, please confirm. Quote
