Darren G Posted April 23, 2022 Posted April 23, 2022 Good Day All. Hope you are well. I have recently installed a solar system at home. I have 1 issues which I need assistance with. I have setup Work Mode 1 instructions for the inverter to discharge from the battery. Something concerning has happened. From 6pm to 9pm SOC must go fromm 100% to 65%. When using the SOLARMAN PV app I monitored the system and found that my house was consuming around 800W however the battery discharge was around 2kw which meant the surplus of 1.2kw was sent to the grid. i need my system to discharge = load requirements and nothing more. What do I need to do to rectify this? Thank you Quote
system32 Posted May 1, 2022 Posted May 1, 2022 (edited) On 2022/04/23 at 10:08 PM, Darren G said: Good Day All. Hope you are well. I have recently installed a solar system at home. I have 1 issues which I need assistance with. I have setup Work Mode 1 instructions for the inverter to discharge from the battery. Something concerning has happened. From 6pm to 9pm SOC must go from 100% to 65%. When using the SOLARMAN PV app I monitored the system and found that my house was consuming around 800W however the battery discharge was around 2kw which meant the surplus of 1.2kw was sent to the grid. i need my system to discharge = load requirements and nothing more. What do I need to do to rectify this? Thank you Best to give us some details 1) model of inverter you have - 5k, 8k, 12k 2) batteries 3) PV 4) photos of Work-Mode-1, Work-Mode-2 5) photos of battery-type, battery-charge, battery-shutdown 6) Any additional setting you think relevant 7) How would you like the system to work? Perhaps the CT coil is incorrect: Edited May 1, 2022 by system32 Quote
