mihaigsm2003 Posted May 4, 2022 Posted May 4, 2022 (edited) Hi, i have for repair inverter MPP Solar U5648 with no display. I see CPU STM32 from communication board is shorted. I try to buy but not found for sale yet. Also, i can change CPU with other new but need write firmware on CPU. Pls any help, if somebody have firmware and jtag connection, thanks in advance! Edited September 1, 2022 by mihaigsm2003 Quote
Coulomb Posted May 5, 2022 Posted May 5, 2022 My wild guess is that it would be a STM32F107VC, same as in the removable displays. But these are ARM chips; I have no idea about JTAG programmers for these. This is a fairly recent model, and I've never seen a firmware update file for this model or any like it (for either the DSP or the display). You might be able to plead your case with MPPSolar, but I doubt it. Also, I strongly suspect that they have a bootloader flash segment in there that isn't part of a firmware update (same as DSP firmware in that respect). I doubt that anyone has extracted that bootloader. Without it, you won't be able to update the firmware in that display via a PC (as I assume it's normally possible to do), and there may be other consequences. But maybe that's not a complete show-stopper. Finally, there is the mechanical task of removing the old chip without damaging the PCB too much, and soldering the new chip without shorting several adjacent pins. I would think you'd need a heat gun with an appropriate attachment for that size of chip to remove the old chip. This is highly advanced repair work. There may be easier repair jobs out there. Quote
mihaigsm2003 Posted May 7, 2022 Author Posted May 7, 2022 Quote Finally, there is the mechanical task of removing the old chip without damaging the PCB too much, and soldering the new chip without shorting several adjacent pins. I would think you'd need a heat gun with an appropriate attachment for that size of chip to remove the old chip. Hi @Coulomb, i working on GSM service, i change BGA chips any day :), to change this CPU is very simple to me. Quote My wild guess is that it would be a STM32F107VC, same as in the removable displays. Is good ideea, but 101% is diferent firmware inside. Maybe same bootloader, also need firmware for display modules. Thanks for reply! Quote
mihaigsm2003 Posted May 8, 2022 Author Posted May 8, 2022 I replace chip with one from detachable display, now i have usb and RS232 communication, light for buttons work, but no display, no backlight, no touchscreen working. now i need lcd firmware for U5648MS Quote
Coulomb Posted May 8, 2022 Posted May 8, 2022 20 hours ago, mihaigsm2003 said: i working on GSM service, i change BGA chips any day :), to change this CPU is very simple to me. Respect! 2 hours ago, mihaigsm2003 said: now i need lcd firmware for U5648MS You will need some luck and/or patience getting that. I guess that this chip already has a bootloader, but it seems unlikely that it will be the exact right one. You might be able to use a display reflash tool for a King or wherever that chip came from, and pair it with the mcu.hex file for a U5648MS, so that the flash initiation commands match. So then it's a matter of waiting for a display firmware update file for the U5648MS, or possibly one of the other colour display models might work. You have less to lose by trying it than most Quote
mihaigsm2003 Posted May 8, 2022 Author Posted May 8, 2022 i gest write some mcu.hex, but not lucky, no display 3 hours ago, Coulomb said: Respect! Thanks! Quote
mihaigsm2003 Posted June 5, 2022 Author Posted June 5, 2022 Hi, any news? Any new firmware for U5648 ? Quote
Steve87 Posted June 5, 2022 Posted June 5, 2022 Hi post me the make and model of this inverter I may be able to help with the display files...it looks to me from the pics like an MKS4 or the MAX2 8kW or 10kW model. Quote
Coulomb Posted June 6, 2022 Posted June 6, 2022 (edited) On 2022/06/06 at 5:11 AM, Steve87 said: I may be able to help with the display files...it looks to me from the pics like an MKS4 Yes, the MPPSolar U5648 is equivalent to an Axpert MKS IV 5600-48. Edit: Oops, the MPPSolar U5648MS is equivalent to an Axpert MKS IV 5600-48. The MPPSolar U5648GK is equivalent to an Axpert VM IV 5600-48. There is also the PIP-5048MKX, equivalent to the Axpert King II. Edited June 7, 2022 by Coulomb Quote
Steve87 Posted June 6, 2022 Posted June 6, 2022 Ok great. Let me see what I can get for you to solve this. Quote
mihaigsm2003 Posted June 6, 2022 Author Posted June 6, 2022 (edited) 13 hours ago, Steve87 said: Ok great. Let me see what I can get for you to solve this. Thanks 6 hours ago, Steve87 said: What was the original U1 U2 & U3? i think U2 was 36.39 02G On 2022/06/05 at 9:56 PM, mihaigsm2003 said: Hi, any news? Any new firmware for U5648 ? U5648MK Edited June 6, 2022 by mihaigsm2003 Quote
mihaigsm2003 Posted June 6, 2022 Author Posted June 6, 2022 (edited) Also, i need firmware for hybrid model (yelow sv4) original 35.73 03G Edited June 6, 2022 by mihaigsm2003 Quote
Coulomb Posted June 7, 2022 Posted June 7, 2022 14 hours ago, mihaigsm2003 said: U5648MK ? I see U5648MS and U5648GK, no U5648MK. Which one is it? The main firmware will be quite different, and I suspect that the display firmware may be different as well. Quote
mihaigsm2003 Posted June 7, 2022 Author Posted June 7, 2022 (edited) 1 hour ago, Coulomb said: ? I see U5648MS and U5648GK, no U5648MK. Which one is it? The main firmware will be quite different, and I suspect that the display firmware may be different as well. Oh, sorry, is MS, U5648MS Edited June 7, 2022 by mihaigsm2003 Coulomb 1 Quote
mihaigsm2003 Posted June 7, 2022 Author Posted June 7, 2022 (edited) On 2022/06/06 at 8:39 AM, Steve87 said: Ok great. Let me see what I can get for you to solve this. Thanks sir for firmware, i will share here: i write only mcu file (U2) AxpertMKS IV5.6K 74.02.rar Remote Panel_Reflash_MCU(36.01).rar Edited June 7, 2022 by mihaigsm2003 Coulomb 1 Quote
mihaigsm2003 Posted June 8, 2022 Author Posted June 8, 2022 20 hours ago, mihaigsm2003 said: AxpertMKS IV5.6K 74.02.rar 1.43 MB · 1 download Remote Panel_Reflash_MCU(36.01).rar 869.89 kB · 1 download This firmware is only for ofgrid inverters Quote
Jaxone Posted June 8, 2022 Posted June 8, 2022 Mihai, the FW is for the units that can be paralleled or no parallel function ? What you used to flash the MCU ? Just on the fly trough USB ? Quote
Coulomb Posted June 9, 2022 Posted June 9, 2022 (edited) 23 hours ago, Jaxone said: the FW is for the units that can be paralleled or no parallel function ? QPIRI (Query Inverter Rating Inquiry) returns 9 for the number of parallelable units. So this is MKS IV firmware. 23 hours ago, Jaxone said: What you used to flash the MCU ? Just on the fly trough USB ? With the removable displays, the on-the-go USB port can only be used to reflash the main firmware. The display firmware is needed to be able to read the USB file system, so the displays can't re-flash themselves. I expect this situation to be the same with these colour, non-removable displays. Edit: so you have to use a Windows PC and a USB to serial adapter, and connect to the RS-232 port of the inverter. Edited June 9, 2022 by Coulomb Quote
Jaxone Posted June 9, 2022 Posted June 9, 2022 I just saw the archive content So it is USB flashing. If this FW is for 9 units that means not suitable for mine .. mine has no parallel function. We will wait a bit more , maybe something shows up Quote
Jaxone Posted June 9, 2022 Posted June 9, 2022 Btw , which field in the return specifies the number of parallel units ? QPIRI (230.0 24.3 230.0 50.0 24.3 5600 5600 48.0 46.0 44.0 52.2 51.5 2 002 040 0 2 3 1 01 0 0 50.0 0 1 Quote
Coulomb Posted June 9, 2022 Posted June 9, 2022 (edited) 5 minutes ago, Jaxone said: which field in the return specifies the number of parallel units ? QPIRI (230.0 24.3 230.0 50.0 24.3 5600 Rated VA 5600 Rated real power Watts 48.0 Nominal battery voltage 46.0 44.0 52.2 51.5 2 ... 002 Max utility charge current 2A 040 Max total charge current 40A 0 Input voltage range (Application) 2 Output Source Priority (SBU) 3 Charge Source Priority (only solar, might be different interpretation) 1 PARALLEL MAX NUMBER <<<============================== 01 Machine type (off grid) 0 0 50.0 0 1 ... etc Edited June 9, 2022 by Coulomb Jaxone 1 Quote
Jaxone Posted June 9, 2022 Posted June 9, 2022 Thanks. Next question would be : Paralleling this units is dependent only on firmware or there are also hardware differences ? (beside the paralleling board) Quote
Steve87 Posted June 9, 2022 Posted June 9, 2022 Glad this firmware and MCU files got you guys sorted. Funny the MKS4 has this issue. I have had a unit suffer this problem in the recent last 3months and yep just seems weird. Just glad you got the disco lights flashing again Jaxone 1 Quote
Coulomb Posted June 10, 2022 Posted June 10, 2022 (edited) 12 hours ago, Jaxone said: Paralleling this units is dependent only on firmware or there are also hardware differences ? (beside the paralleling board) I don't know these new models; I'm still reading the firmware. On the older models like the Axpert VM III, the processor is a smaller version with less flash storage. The cut-down firmware has to be compiled with optimisation to squeeze it into the available space. I don't know if that's the case with these later models. In the older models, I think that there was no actual connector for the paralleling board; the control board was cut down as well. They also saved ink by not printing parts designators (e.g. Q30, R127) on the underside of the main board. Some smaller VM models used an 8-bit MCU instead of the 32-bit DSP used in higher power models. In some cases, there was no control board at all; the controller was put directly on the main board. So the chances of being able to just changing firmware and popping in a pair of paralleling kits is low to non-existent. The commands processed by some of the VM models is also slightly different. The display firmware has to constantly check what model it's dealing with, and modify the commands accordingly. I think that's a poor design decision, but early on, the designers probably had no idea how many models would eventuate, and how strong the need would be for uniformity. I pity the likes of ICC and Solar Monitor, that have to try to deal with all the different models and their minute but important differences. Edited June 10, 2022 by Coulomb Riyad179 and Jaxone 2 Quote
