Could anyone please tell me which cable to use with the Kodak BL3.6 when connecting to a 5kw Sunsynk inverter. I can't see anywhere where the cable is mentioned in the manual it only states it is compatible with Sunsynk. Is the CAN port used and what is the pin-out configuration.
Thank you
I have the same questions, but with Kodak BL3.6 + OG5.48 inverter. Info out there very thin about the BMS communication cable for this pair.
Hi Paul,
Did you win here? Also looking for cable with same combo.
