JuanF Posted May 11, 2022 Posted May 11, 2022 good day all your clever people. I got a Axpert king inverter (5kWa) with panels working for years now. Upgraded to Pylontech batteries and now i am experiencing problems where my PV switch off once my battery hits 100%. i then manually needs to go and disconnect my strings and re-connect to get my PV going. I heard that it might be a problem with the firmware. currently running 71.50 firmware and looking for 71.94 or greater. anyone know where i can find this and if this will resolve my problem? Quote
Coulomb Posted May 12, 2022 Posted May 12, 2022 15 hours ago, JuanF said: I heard that it might be a problem with the firmware. currently running 71.50 firmware and looking for 71.94 or greater. It's a firmware problem, but I am not aware of any version that fixes it. 15 hours ago, JuanF said: anyone know where i can find this On this very forum, in the files section: 15 hours ago, JuanF said: and if this will resolve my problem? I'm fairly sure it won't resolve that problem, though 71.50 is quite old, and there were definitely some solar charging problems with the early firmware versions. So it's certainly worth a try. Quote
Coulomb Posted May 12, 2022 Posted May 12, 2022 If you're using a direct-to-BMS cable, it's probably also worth updating the removable display firmware. 02.70 is available from this post: Quote
