Connecting a 1p grid tie inverter to Deye 3p hybrid
I've got a Deye 12kw 3p hybrid inverter at home. I might need a few exra mppt's to manage more strings. One of the simplier ways is to connect a grid tie inverter to the gen port and let te dye manage it. Do I need to connect a 3p grid tie inverter, or would it potentially be possible to use a 1p gried tie inverter?
Do you want to add the grid tied as a gen input while you have the 3ph connected to a grid connection?
100%
I basically need another MPPT / inverter for another set of solar panels pointing in a different direction. Looks easy to add an inverter to the gen port, just not sure if it needs to be a 3p or if I can use a 1p inverter.
6 hours ago, Danger said:
100%
Not sure why you want to connect a grid tied on the hybrid. A grid tied generates 220V AC so why not connect direct on the main incoming AC. It then generates AC from the panels via it's built in MPPT.
