Jonny Posted May 18, 2022 Posted May 18, 2022 I have a 24V setup with a RCT Axpert 3kv inverter, I have recently attached solar leads to test a panel array. After removing the solar array and wires ime still getting a 10W charge reading from "solar" and also reading a pv_input_voltage of 19.5 v Has anyone seen this before, how can i resolve this? Quote
Coulomb Posted May 18, 2022 Posted May 18, 2022 52 minutes ago, Jonny said: After removing the solar array and wires ime still getting a 10W charge reading from "solar" and also reading a pv_input_voltage of 19.5 v My guess is it's rounding/measurement errors for the power, and the voltage is battery voltage less several volts through various components. As long as you get sensible readings when the panels are active, I would not worry about this. Jonny 1 Quote
Jonny Posted May 18, 2022 Author Posted May 18, 2022 @Coulomb - Thanks for the feedback. It does mess with my monitoring but ile make changes to my stack. Quote
