RCT firmware patch .... Ime afraid.
Hey there,
I have a RCT Axpert 2k inverter and it is bugging me because it has the premature Float bug. It wont even hit the programmed float voltage.
I want to update the firmware to fix this bug. Where can i find this fix ?
ALSO I dont have an idea how to do this. Is there a guide you guys can recommend???
In an ideal world, the manufacturer or their distributors would have them listed on web sites. indeed, they did until the first clones started arriving.
Alas, 2 kVA firmware is hard to find, and there isn't a patched firmware available. So there is no firmware fix for the premature float bugs in these models.
It should reach within about a quarter volt of the float voltage for 24 V systems, or your issue isn't the premature float bug. (Half a volt for 48 V systems, and I don't know about 12 V systems).
Does your inverter have timed absorb or equalise settings? If so, they can be used to work around the problem. But the lower power versions tend not to have these.
Low power models also tend to have very low power Solar Charge Controllers, like 600 W (25 A x battery voltage). If so, that could be why you struggle to charge the battery. Perhaps consider an external MPPT, connected directly to the battery. You might still want to use the internal SCC as well.
Posted (edited)
@Coulomb - Thanks for the response again. It did finally reach the float voltage. Is there a way i can factory reset the inverter to set it back to "normal" ?
The other irritating thing is that the fans spin every 30 min even with no load. This was not the case before this issue.
If i have to get an external MPPT them maybe it would be better just to return/refund the @#$% thing and get a Growatt/whatever ?
UPDATE : I managed to get it to not stop at float by doing the following.
1) Removed AC and PV power
2) used 20% of by battery capacity.
3) Disconnected battery then reconnected battery
4) While off added the PV again
5) added load
6) added AC
Now if is charging without "is_charging_to_float" true and is charging to bulk voltage.... BUT when the SOC reeds 100% it goes to float and does not go to user defined voltage
Edited by Jonny
I'm finding this hard to follow. You say it's charging to bulk voltage, good. The SoC reading is based entirely on battery voltage, as measured by the inverter. For a 24 V model, it's something like 2% for every 0.1 V in excess of (setting 29 plus 0.1 V). I don't think it triggers anything from a 100% SOC reading. But if it does, you can adjust what it thinks is 100% SoC by fiddling with setting 29 (low DC cutoff voltage).
When you say "does not go to user defined voltage", what voltage does it go to, and what voltage are you expecting it to go to? It can take a battery some time to change voltage, depending on charge current, load, temperature, and internal state. Is it lead-acid, LFP, or other battery chemistry?
Let me try again (please remember this was not the case until i connected PV)...
My settings are
Bat_voltage = 24V
Float = 26.8V
battery_bulk_charge_voltage = 27.8V
cut off voltage = 24V
Even with these settings, as soon as the inverter reads 100% SOC (this is not correct when it comes to lifepo4 because you can not determine this purely on Voltage). it instantly goes into float state .... It never even hits the bulk/absorption voltage of 27.8.
Note: i have a balances that balances the 2 batteries at 27.3 v. This never happens because the inverter never hits high enough voltage.
This is the issue.
Before it adhered to the setting and when it would go into float it would maintain (without fans) the voltage with no issues, now the fans spin up every 20 min.
Posted (edited)
What version is your main firmware? It's slightly possible that I've already patched it.
Edit: re the change in behaviour: have you changed the maximum charge current (setting 02) between when it was working and now?
Posted (edited)
No i have not.
My current version :
U1 09 52
U2 03 39
That would be really awesome. Thanks for the assistance.
Is there not a way i can "factory reset" the unit to get it into the previous state?
Just for ref: https://www.rctzone.co.za/power-solutions/inverter/off-grid-inverters/rct-axpert-vm-2k-24v
Edited by Jonny
Yes, with WatchPower or other monitoring software, there is a facility to reset to factory defaults. That defaults all the user-accessible settings to defaults, so that might work.
It uses the PF (Put to deFaults) command. There is a stronger command that resets nearly everything, but I think you might lose all voltage and current calibrations, etc. So that's really only for the factory to use.
@Coulomb - thanks - please share how i can do that. I dont mind loosing the calibration.
Sorry, I'd rather not. I don't know what the full implications are, and I suspect that they would be severe.
I suspect it would not help with your situation anyway.
