Johann Fourie Posted May 24, 2022 Posted May 24, 2022 Good day everyone, I have installed a 3kw SPF3000TL HVM 24v Growatt inverter with Pylontech UP2500-24v battery and 2 X 400w panels on this system. I believe I need to make up a different comms. cable and have already tried different options in made-up cables. As a 63y old person, I know nothing to very little of what settings my system needs to be, however after trying 4 x different installer to help (at a cost), the system is still not communicating between the Battery and Inverter. Could you please advise what cable I should have made up as well as what ports they must be plugged in. Also, the setting on the Inverter after installing the suggested Cable will help please. Quote
